    NAE Archeive Fail
    Good-day
    We have come across a NAE that says - Archeive Failure.
    We can upload \ download okay - Is the NAE on the start of failure.
    Oct 2008
    Twin Falls, ID
    I have had this message many times. I think the NAE just gets bogged down with too many uploads/downloads. The best thing to do is to right click the nae, go to commands and hit archive. Then do the same thing but do a reset. If the message is still there when it comes back try a hard reset, by removing the power and then the battery.
    There could be some unbound references or broken logics. Try go into the 'Expert Mode' and check it out.
    Unbound
    I checked for unbound reference - no issue. -- Why would you go into expert mode for this?
    it tells you the errors when archive has failed. Sometimes it could be missing resource file.
