Results 1 to 13 of 15
    Huntsville,AL
    typical hi RH-winter, here
    at 6am, dry bulb= 23F, wet= 21F = ~95%RH
    so,
    sealing attics & crawlspaces prevents sucking in moist air;
    probably best to forget vapor barrier --
    this hi RH will typically be until 10am --
    so,
    don't make firm statements that one should draw in outside air;
    unless
    it is conditioned --
    Saint Joseph, MI
    It's 95% RH... the key term is RH. That amount of moisture at the indoor temp of 70F, is only around 25%RH if I read my Psychrometric chart right.
    A <25F dewpoint is still pretty dry.
    Maybe I'm understanding your statement wrong. As a pro, I'd think you'd know this already. The saturation point of air it terms of how much moisture it will hold decreases as temeprature decreases. So saturated air at 20F, hold 1/4 the amount of moisture as air at 70F.
    Ideal conditions of 40-45% RH at 70F is a dewpoint of around 45-50F. So to better understand this, if the home is an idea 45% RH at 70F, then any indoor surface that is <50F will have moisture on it. This is why windows have moisture at low outdoor tempratures.
    I could be wrong.
    But, at 23F DB and 21F WB the RH is 75.1%, 13.0588 grains per pound of air.
    At 70F DB and the same 13.0588 grains of moisture, it would be 12%RH.
    According to my Carrier chart.
    Fort Worth, TX
    I could be wrong.
    You are correct on both counts.
    cems-bee wrote:
    so,
    so,
    unless
    Beenthere (along with motoguy) is correct again, in that drawing in air under the conditions you gave is still dry air, and will lower indoor RH levels if not humidified (or if indoor moisture generation is low).
    Any vapor barrier, to my understanding, should be on the drainage plane of a wall (behind the siding or cladding, in front of the sheathing), not on the interior. Housewraps are air and liquid moisture barriers, but allow vapor diffusion (allowing a wall cavity to dry to the exterior as well as to the interior).
    Building Physics Rule #2:
    Building Physics Rule #3:
    Feb 2007
    Quote Originally Posted by shophound View Post
    How about fiberglass insulation w/paper vapor barrier, applied to the sill (not sure if this is the correct term, but is first wood above grade on top of cinder block).
    The barrier is on the inside face of the insulation.
    Thanks.
    Amp
    Fort Worth, TX
    Quote Originally Posted by ampulman View Post
    Thanks.
    Amp
    Do you mean something like this, where a framed stem wall sits on top of the basement wall or crawl space wall? :
    In the drawing, notice the lack of a vapor barrier to the interior, and why. The interior plane shows drywall painted with latex, to allow drying of the wall cavity via vapor diffusion to the interior.
    If you're speaking about a different configuration (such as an above grade block house) please specify where this is found in the house.
    Feb 2007
    Yes, this is a basement w/10 ft cinder block walls. The cinder block extends about 1.5 feet above grade. There is an attached crawl space which has the same treatment.
    The basement is unfinished; hence no interior walls.
    Would I assume correctly, that my 'configuration' doesn't pose any problem?
    Thanks.
    Amp
    Fort Worth, TX
    Thanks.
    Amp
    The fiberglass batts...are they attached to the basement wall, or the crawl space wall? Is the basement wall exposed block, or does it have a framed wall in front of the block to contain insulation? The crawl space...is it ventilated? Is the floor over the crawl space insulated?
    Saint Joseph, MI
    I could be wrong.
    That's probably right. I just "eyeballed" a chart I found on google that wasn't specific to HVAC. The Carrier chart is probably a little more precise (easier to read). I had to convert from celcius as well.
    Feb 2007
    The basement wall (cinder block) is below grade, with the exception of about 1.5 ft. On the top block (above grade), there is an approximately 2 x 5" board laid flat, on which 2 x 8 joists are placed. At the top of joists is the first level sub-floor. This (8") is the space which contains the (kraft paper inward) faced fiberglass. This is all open to the basement.
    The crawl space is basically the same, except that the joist level is split (lowered) from the main (first floor) about 8". The crawl space is under a section of house which has no second floor, and contains heating ducts, pvc furnace vent pipes, and plumbing.
    There is fiberglass (about 1") board on the walls; some thick material on the floor. The space is open to the basement and is not vented to the outside. It is on the cool side.
    Thanks.
    Amp
    Huntsville,AL
    read about vapor barriers at BUILDINGSCIENCE.com
    so, I did not carefully note my dry bulb, I focused on the wet bulb & RH%.
    nevertheless, every thing I have heard or read from the health 'experts' is that RH% should be kept between 35 & 55%.
    No body stated that it was dependent upon temperature.
    so, maybe my bdrm @ 57F does not have much moisture per cubic ft, but it is still on the high side [60+ percent], especially during the early morning --
    If you know WB and RH, you can find/determine DB.
    Huntsville,AL
    why look-up or calculate when I can just read my instrument?
    I suspect that I did my first look-up in 1961 --
    again, what is your 'take' on RH% needed ID for good health, even at 57F?
    at 67F?
