Page 1 of 4 1234 LastLast
Results 1 to 13 of 46
    Question Teach me about disposable pleated filters
    Questions:
    1. Given the same materials, is it correct to say that a 2" thick filter will last twice as long and have half of the pressure drop of a 1" filter?
    2. What minimum MERV is sufficient to prevent mold from growing on evaporator coils?
    3. How can 2 new filters of the same thickness and MERV rating have different pressure drops?
    4. Who makes 2", 4" and 6" thick filter grilles?
    5. What filter brand is the best value (i.e. best quality for the price)?
    6. How much pressure drop do you consider acceptable in a new filter?
    I don't know
    Questions:
    - Not necessarily, you have to consider media surface area.
    - I don't think any filter alone can prevent mold from growing on an evap coil. Get a mid range filter, and replace it as required.
    - Different material
    - google it
    - That depends on who you ask
    - I think "acceptable pressure drop" greatly varies between systems
    Given the same materials and construction, doesn't a 2" thick filter have exactly twice the area of a 1" filter?
    - google it
    I did - nothing came up.
    I'm asking you and everyone else here who knows more than I do.
    Alright, let's say the system is a Ruud UBHC-17J11NFD air handler over a Ruud RCBA-3765G indoor coil.
    Aug 2008
    go to
    dirtyfilters.com
    Camfil Farr rocks
    Illinois
    Get a middle of the line one and change them often.
    Nov 2008
    Bristol Va.
    Quote Originally Posted by charles2 View Post
    - - I think "acceptable pressure drop" greatly varies between systems
    pressure drop takes into consideration size and design of your ducts, supply grilles and return grilles not mentioning the evap. coil and of course your filter.
    if your system has a high pressure drop of say over 1.5" w.c. then you can't use a pleated filter as it will be too restrictive. on the other hand if your pressure drop is low say .5 " w.c. then you can use a more restrictive filter.
    so call out your contractor and ask them to check the presure drop of your system and then you will have your answer. to what is acceptable pressure drop.
    dogboy
    Jun 2007
    Round Rock
    Get a good mid-grade filter. Go to Home Depot and don't buy the 59 cent filter or the $15 filter. Buy the $3-$8 filter and you should be ok. If you're concerned about mold growth, put a UV light in. Once you pay the initial installation fee. There will be an annual cost to replace the bulbs as well. It isn't cheap, but they do work.
    I like DIY'ers. They pay better to fix.
    Cedar Grove, Wi-Sheboygan
    I have to ask a ? about those UV lights, there;s many here that claim they work and there's others who say they do nothing, so the real question is are UV light's nothing more than say a placebo affect to the individual or is it more of a peace of mind type thing. And if they really do work how would one know if they should have one installed ?
    Jun 2007
    Round Rock
    Quote Originally Posted by DanW13 View Post
    We've installed many and they seem to keep the inside of the coil area cleaner. I put one in my house several years ago and my wife's allergies got significantly better. I did something stupid about 2 years ago. We just installed new bulbs in a system and the homeowner complained that there was a burning smell in the house. I took them out while they were on to make sure we didn't get mastic on them or something. It was out for maybe 10 seconds, it burned my eyes whereas I couldn't even open them up later that night, it felt like sand was poured in them. I called the manufacturer as to the burning smell and they said that was normal for about 24 hours, the old ones had lost their "punch" and the new ones were killing off the new growth. I personally think they work.
    Quote Originally Posted by bmathews View Post
    When you develop cataracts you'll know why.
    Nov 2008
    Chapel Hill, NC
    Warning! Scientific hypothesis only. This is purely speculation based upon my research experience in bacteriology and virology using UV sterilization hoods. I suspect the UV light in the coil case works in killing stationary mold ansd spores because the UV exposure is continuous. I cannot fathom how the lights in the return ducts have any effect on moving bacteria, etc, in the air as the exposure time has to be way too short (less than a second at typical duct air velocities).
    Anybody have any reliable data on either of these hypotheses?
    Keith
    Nov 2008
    Bristol Va.
    How are your eyes now?
    dogboy
    Saint Joseph, MI
    Quote Originally Posted by sktn77a View Post
    Keith
    So the question is, how long of a exposure is required and at what distance and intensity? This is probably something that's been debated in the IAQ forum for a while. The best design would have the bulbs in parallel with the airflow on the sides of the duct with a reflective surface on all sides of the duct. I think placement near the coils and drain pan ultimately is the best option.
