Results 1 to 14 of 14
Thread: 19xr comp o-rings & gaskets
    what do you use on the o-rings & gaskets? 515?
    Northwest GA
    Don't know 'bout the rest but I use Parker silicone lube on the rings, seems like there are 2 different kinds I'd have to check to be sure, one is not reccomended for the high pressure stuff. Gaskets I just lightly coat with whatever oil she runs on. Never had a problem.
    Dec 2008
    Dixiana, AL
    Dow Corning 111 silicone grease always gets my vote on the o rings. If I use anything at all on low compression fiber gaskets, it's generally Loctite 567 (I know it sounds odd, guys, but I've done it countless times and never had a problem or a leak) in VERY thin coverage.
    pritzberg
    depends on the area needing sealing. on o-rings, generally purple jelly. vacuum grease on internal seals. oil or grease on gaskets. without making me look it up, what's 567?
    Dec 2008
    Dixiana, AL
    Quote Originally Posted by heavymetaldad View Post
    Loctite 567 is the thread sealant designed for stainless steel fittings. Works great on a lot of applications, although I don't like it on lube lines. Completely out of necessity, we discovered one day that applied in a very thin coating (see-through) on material like Garlock 3000 and 3300, this stuff is an excellent flat surface sealing aid. A little hard to clean up if disassembly is ever necessary, but well worth the trouble in exchange for the benefits, in my opinion. Moly paste is the best release agent for these gaskets, but doesn't have even close to the sheer strength of the 567.
    Thanks guys for the input. This is a cool website.
    pritzberg
    Quote Originally Posted by klove View Post
    the white teflon paste in a tube? use that on fittings to be taken apart. use loctite reefer sealer on stuff that'll stay together forever. i'll have to try it on a gasket sometime.
    Maryland
    567, thats the teflon like sealant right. I like to mix the 567 with 554 for threaded fittings. Is this common with anyone eles? Rubber, neoprene, or butyl gaskets i put on dry due to the gasket squeezing out.
    Pacifica, California
    Carrier recs Parker O Super lube. Trane recs Loctite 515 (grape jelly) York recs their own oil. I one the other hand am a big grape jelly fan. Thinly coat. Never leaks. Orings only.
    Rubber gaskets install dry. Cork also.
    Good luck.
    pritzberg
    anyone use 'carrier's' parker gasket sealant? the thin brown stuff? used it once, it failed, never again
    Oct 2007
    Mechanicsville, VA
    Quote Originally Posted by ryjowy View Post
    Good luck.
    As I overhaul Centravac's I would disagree with this statement that you put cork gaskets on dry. I reccomend burying the o-rings in 515 and also completely covering the cork gaskets in 515. Rubber, butyl, or neoprene must be dry or they WILL leak, and garlock gets a coating of oil that is not forigen to the compressor mixed with WD-40 (Just enough WD-40 so that it is thin enough to spray from a bottle) This oil/WD is also applied to all components while they are off the compressor to prevent corrosion.
    Wichita Ks
    I have used it only on flange gaskets. No leaks yet.
    Northwest GA
    Quote Originally Posted by Mike Soucy View Post
    I like the WD-40 idea. I put the oil in a spray bottle and use that on the flat gaskets (garlock). The neoprene, viton , rubber go on dry. 'cept for orings.
  14. #14
    pritzberg
    Quote Originally Posted by freonrick View Post
    used it on a lo side float box cover on a 2000t cb. leaked like a sieve. made a new gasket and used a little dte on it, no probs
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
