    Rochester NY
    Stop installing furnaces...
    https://play.google.com/music/m/Df7c...Techs_By_Techs
    Nate Adams: gas meter assassin, on heat pumps in colder climates...
    Athens, Ohio
    That link to play.google doesn't work for me.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
    Oct 2016
    NY
    I'll have to watch or listen to it later
    Mar 2015
    Hamersville, Ohio
    "HVAC School - For Techs, By Techs"
    Same here, it just "sits & spins".
    I don't know
    Quote Originally Posted by tedkidd View Post
    I'm starting to listen now.
    Gas is the fuel of choice for new power plants. Nuclear isn't being built, coal is going away thinks to silly "green" energy policies and artificially cheap gas thanks to shale producers over-producing gas just to service their debt.
    My question is, is it productive to do this when the electricity is produced by burning natural gas to begin with?
    Might as well burn the gas directly.
    A heatpump has to have a cop of 3 just to break even in energy consumption compared to a 90%+ furnace, power generation and distribution losses considered.
    When it's 0F outside, no air source heatpump will be running with a cop of 3. All but the new inverter ones will be relying on some form of backup heat.
    Also, you have to have a really high performance building envelope, a cold climate heatpump and generously sized ducts to heat without using any backup.
    Most people don't have the dollars to afford to insulate exterior walls and spend $10 to $25k on a top of the line heatpump system.
    This may make sense in states/provinces that mostly have hydro-electric and nuclear.
    Natural gas is an amazing heating fuel - in areas without a lot of hydro capacity it would make more sense to just not burn gas to electricity. Only to use electricity to heat water and cook with at 25 to 40% effective efficiency.
    Then the gas resources would last a lot longer.
