Results 1 to 11 of 11
    Aug 2014
    new york
    need wiring help
    hello techs does anyone has a wiring diagram of a hvac unit wired in to a alarm system basic wiring method that would shut down system & cause alarm,also need basic to moderate type of wiring diagram of a hvac wired to a building automation system,need to revise it will be having a knowlegment test just want to revise it,any information will help
    Mar 2013
    Billington Heights, NY
    can you turn this into a complete paragraph with sentences, please?
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
    Jtrammel - "Im going to sell hvac systems derp derp derp"
    BBeerme - "every time he opens his mouth, he reminds me of a cow without the fart bag."
  3. Likes kdean1, jbmoore5 liked this post
  4. #3
    Jun 2014
    Dover, DE
    The BAS is a hugely loaded question. That all depends on what protocol it is, how your wiring in to it, and so on.
    For the alarm, basic alarms can be done via BAS. Is this a fire alarm?
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
  5. #4
    Dec 2013
    London
    Quote Originally Posted by nytech28 View Post
    You what???
  6. #5
    Athens, Ohio
    Quote Originally Posted by HVAC_Marc View Post
    Like with capitals and punctuation and complete thoughts? That's so 90's.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  7. Likes DaveCR, HVAC_Marc, BALloyd liked this post
  8. #6
    Nov 2016
    To the OP:
    These guys are tough but there is a reason. They are pros. That doesn't come for free. Make complete sentences and be respectful.
  9. Likes stanbyyourword liked this post
  10. #7
    Aug 2014
    new york
    Quote Originally Posted by rider77 View Post
    no,to some type of panel that will cause alarm when Ac unit safety controls open
  11. #8
    Jun 2014
    Dover, DE
    Umbrella answer but that can be done via BAS.
  12. #9
    Aug 2011
    Southeast PA
    I was going to post a smart ass comment, but instead I'll offer this low-effort mspaint sketch. You want the safety devices to be in series with a multi-pole relay. The separate NO/NC contacts on the relay can then be used for interlock of the equipment, indication to the BAS, and indication to the alarm system, or whatever else is needed, provided your relay has enough poles.
    Good luck
    https://imgur.com/a/mwVZv
  13. #10
    Aug 2014
    new york
    thank you for the info
  14. #11
    Jun 2012
    Northern NV
    Very simple solution is a relay coil in parallel with the NC limit switch. Switch opens and places potential across the coil. Actuates a switch closure which can light up a signal or a buzzer. Not automation, but quite simple annunciation circuit.
