+ Reply to Thread
Results 21 to 31 of 31
Thread: Capacitance Meter/Microfarads
  1. #21
    Quote Originally Posted by ChrL_Brann View Post
    But my flukes will zero on amps will yours?
    i gave you the book that shows how to check capacitance without a meter
    mine likes to get a head start at 3 tenths lmao
    but! my ohm scale see's things yours wimpers on
  2. #22
    Jun 2007
    Greenville,North Carolina
    LOL
    Look to the past to learn;look forward to live.
    Coach Dean E. Smith
  3. #23
    MASTIC BEACH
    fluke337
  4. #24
    maui
    You dont even need a capacitance function on your meter. You can check the capacitor under a load by using this simple calculation
    Take the amps off the start winding multiply that by 2650 and then divide that number by the voltage across the capacitor
    2650 is a constant
    so let say my compressor is drawing 6.8 amps on the start winding. Now I multiply that by 2650 which gives me 18020 now I divide that number by the voltage across the capacitor if you have a dual cap than you would be reading across common and herm so lets say that number was 364 volts so
    18020/364=49.505495 So if our cap was a 50uf we would be in pretty good shape
    What cant be done correctly shouldn't be done at all
  5. #25
    Nov 2008
    Quote Originally Posted by ryand View Post
    2650 is a constant
    This assumes the current through the cap is 60 Hz wave, and might possibly have to be a sine wave. I'm not sure the freq. the cap sees doesn't depend on the motor speed.
    V = IZ, and Z for a cap = 1/(2xPIxfxC)
  6. #26
    Jan 2006
    Hamilton Ontario Canada
    I think I will just stick to my Fluke 902. Forget about the math its quicker to use the meter.
  7. #27
    My UEI DL389 is pretty good for caps, you have to give it several seconds for the reading to stabilize on the larger caps. It's been a decent meter except when the batteries get low just before the low battery light comes on.
  8. #28
    Houston, TX, USA
    Thumbs up
    FLUKE 902 and 179
  9. #29
    Oct 2009
    aiken s.c.
    Smile checking capaciters
    I use my fluke16 or 116 even though i have a supco meter.I wish they still made the fluke 16. It has really been an alround good dependable meter.
  10. #30
    Saint Augustine, Florida, United States
    The run cap bandit only cares about one thing. If it ain't in a box, he's selling you one. Some guys don't even check 'em. How about the shake test? How about the rust on it test? Ugh.
    Fluke 16 and recently the FP sc76. Both meter the same on quickie stuff.
  11. #31
    Fieldpiece SC76 or SC77
    Works just fine for what I need... Including caps.
    The other week, my Plasma TV quit... After a few hours of googling, I find that the power supply board is probably the problem. I took it apart and starting checkign caps on the power supply board. FP meter worked just fine... even the itty-bitty caps.
    OH, BTW: found a replacement PS board for the TV, it is in transit to me as I type. If this works, I guess I can add TV tech to my skills...
    GA-HVAC-Tech
    GA's basic rules of home heating and AC upgrades:
    *Installation is more important than the brand of equipment
    *The duct system keeps the house comfortable; the equipment only heats and cools (and dehumidifies)
    *The value of comfort, over the long term; leave economic choices behind!
    Choose your contractor wisely!
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
