Results 1 to 10 of 10
Thread: Din Rail Cutter
    Oct 2014
    Din Rail Cutter
    Has anyone seen a portable DIN RAIL Cutter ?
    Nov 2008
    Long Island NY
    Quote Originally Posted by MECHELEC View Post
    Yes
    Sent from my SM-N910T using Tapatalk
    Etters PA.
    Quote Originally Posted by Jettinvr6sc View Post
    Yes
    Lol sorry that was just funny
    Sent from my SM-N920P using Tapatalk
    Apr 2006
    s.c.
    i love my 12v Milwaukee band saw, its small and perfect for when im doing control work like running conduit and cutting din rails
    Oct 2014
    Quote Originally Posted by coolerinfrederick View Post
    Thanks I will check it out : )
    LEHIGH VALLEY, PA
    see so little din rail used here . When I come across it usually from Europe / Asia . Contactors, relays , fuse holders, timers , terminal, breakers , etc etc , just snap on to a din rail . But No not to much in the states , screw every thing down individually .
    Jan 2010
    Sea to Sky
    Yes. Milwaukee M18 Grinder with a cutting wheel.
    Sent from my SM-N910W8 using Tapatalk
    Dec 2017
    Have seem them but not at jobsites there to big, comes in 2 versions manual or hydraulic driven, i’m from holland and its thru that 99,9 % of electrical fuses, switches and controllers is mounted on din rail’s in circuit- or (main) fuse -boards...
    Jul 2013
    upstate NY
    Splain to me how to use a band saw to cut a din rail.How do you get blade thru hole? Unless starting at edge and leaving loose in a track insted of din snap mount.
    Jul 2010
    Din rail for everything. Cutting it with portable Milwaukee bandsaw
