    Oct 2017
    Can an exhaust fan be used as an intake?
    Hi all.
    Can a fan such as the below be used as an intake, provided Its placed the right way (would also use ducts)
    Seems like so many more options on the exhaust side vs intakes.
    Application is for a wattage intense server room...
    https://www.industrialfansdirect.com...oducts/ce16-dv
    Jul 2017
    Quote Originally Posted by urymoto View Post
    Hi all.
    Yes, in theory you could but you should be able to find something fairly easy it's actually designed for the intended application instead of trying to modify it.
    Sent from my VS988 using Tapatalk
    New Mexico
    Prop fans aren't usually chosen for any restrictions like ducts. In a case like that a centrifugal type or vane axial fan should be used.
    Fans used for exhaust don't have the impact on the space as much as a fan that blows into the space. The analogy is it's hard to suck out a match.
    Anything built to code is built to the minimum legal standard
    You can be anything you want......As long as you don't suck at it.
    SMW Lu49
    Oct 2017
    Many thanks
