    Dec 2014
    midwest
    Light conversion
    Looking for suggestions for LED lighting for WIF with RI doors. What have you used and liked?
    Decent warranty policy?
    Which 'k' number looked good?
    Ease of install?
    I'm seeing 5000k advertised mostly.
    Most lamps I run across are 2700 or 3500k.
    (This place is more into the yellowish lighting. Not the harsh c-store stuff) thanks
    Sent from my SM-G930V using Tapatalk
    Jul 2000
    Cuenca EC
    Quote Originally Posted by icy78 View Post
    Ease of install?
    When they came out with special florescent lamp temperatures back in the 80's the market chain I worked for opted for SPX35, which is at a temperature of 3500K. It was excellent at making the colors of the products "pop". It was an "enlightening" experience to see side-by-side demos of the old standard cool white lamps against these new ones. It was an easy sell to the "suits" in the company because the meats looked so much fresher.
    To me, the 5000K lamps look too cool and almost blue like the old cool white florescents.
    Check out Icemeister's Back Room
    Read My Latest Rambling:
    What Is Mechanical Subcooling?
    ...and a new calculator:
    Nitrogen Pressure Calculator
    Mar 2013
    Billington Heights, NY
    the higher the color temperature the more blue the lighting will be. Daylight is 5500-6500k. Below that the light becomes more yellow and red. Below daylight is considered warmer light. It shows colors better. Above daylight is considered cooler light. Color eventually fades but then pops back in various forms once ultraviolet is reached.
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
    Jtrammel - "Im going to sell hvac systems derp derp derp"
    BBeerme - "every time he opens his mouth, he reminds me of a cow without the fart bag."
    Dec 2014
    midwest
    Thanks. I looked at some stores with 5000k lighting. I also think it's too blue. I have a sample 4000k light being dropped off today.
    I'm also thinking that the angled pattern is nicer, because the lights don't show then. (Just shines on the product)
    Apr 2005
    Australia : Queensland
    Ease of install?
    http://www.ecopoint.co.nz/assets/Pro...-Tubes.pdf.pdf
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
