Results 1 to 4 of 4
    what do TXV temperature ranges mean?
    If I have a TXV rated for (I am making this up) say; +10 to +50
    And I have a like-kind TXV which is rated for say; -10 to -50
    Assuming refrigerant and capacity ratings are the same between the two valves - what would the actual difference be?
    How are the valves actually different from each other?
    What would happen if the two were interchanged with each other?
    PHM
    Oct 2016
    NY
    I'm guessing the sensing bulb refrigerant, or the springs in side?
    This is just a guess, but I suppose a R22 TXV for a walk in cooler is different than a R22 TXV for an A/C unit, even if it were there same tonnage.
    Yes; I'm sure they are different. And the maker notes that they are different when they publish the applications data. But what I am curious about is: Different In What Specific Way?
    Can you think of a reason why the sensing bulb refrigerant charge would need to be different for different temperature range TXV's?
    Spring pressure might be it - as lower and lower operating temperature would produce lower and lower equalizer line pressure.
    Equalizing pressure is a closing-force - so less of it to oppose diaphragm pressure would tend toward the overfeeding of refrigerant through the TXV.
    PHM
    Quote Originally Posted by pitbull14218 View Post
    PHM
    Apr 2016
    Quote Originally Posted by Poodle Head Mikey View Post
    Typically, the +10 F to +50 F would use a C charge in the element and the -10 F to -50 F would use a Z charge in the element.
    The valves are the same except for the charge in the element.
    If the valve with the Z charge is applied in the +10 F to +50 F application, then the valve will operate at a high superheat. Same for the C charge applied in the -10 F to -50 F application.
    Bulletin 10-9 with an explanation of TEV Operation can provide more detail. http://sporlanonline.com/literature/10/10-9.pdf
  5. Likes CHAINIK, icemeister liked this post
