Results 1 to 12 of 12
Thread: MANITOWOC
    Jun 2017
    MANITOWOC
    Found this friday
    On a MANITOWOC ice machine.
    Our company got called after another contractor.
    Yeah thats a HPR valve put in place of txv.
    LOL
  2. Likes joejax liked this post
  3. #2
    Jun 2017
Size:  98.3 KBName:  IMG_5122.JPG
  4. #3
    Jan 2010
    Sea to Sky
    Lol.
    Sent from my SM-N910W8 using Tapatalk
  5. #4
    Aug 2013
    Omaha
    LOL
    Sent from my SM-N920V using Tapatalk
  6. #5
    Oct 2011
    Harrisburg, NC
    Uh.
    I can't fix it if it won't stay broke..
  7. #6
    Feb 2016
    Florida
    Errr....was it making ice? ;/
  8. #7
    Oct 2011
    Chicagoland Area
    Clear example of an experienced tech making the diagnosis and sending a greenhorn out to make the repair.
  9. #8
    Jun 2017
    It was not producing ice.
    The coustomer said it made a few pieces the day they repaired it.
    When i got there the refrigerant had all leaked out.
    The brazing on suction side has a leak and low side shrader valve core leaks.
    The error log on Indigo controller showed repeatedly High pressure cut out
    Faults.
    I'm not sure what the original problem was ,i am assuming it was low on charge due to shrader valve core leak.
    I'm going back Monday with a new txv .
    BAKER supply had to order.
    Once i get new txv installed and replace shrader cores I will see what i get.
    I will repost what results are.
  10. #9
    Wisconsin
    Lol, nice find. Maybe the parts house screwed up, and the tech they sent was too green to know it was the wrong part.
    The remote condenser machines do use an hpr valve.
  11. #10
    In a boiler room
    No. Way.
  12. #11
    Jun 2017
    Return trip
    I installed new Txv.
    Found machine would not harvest,and the fan cycling switch would not cycle fan on.
    So i got a new harvest valve and fan switch and installed those components.
    Now machine is performing to design specifications.
  13. #12
    Jul 2011
    Beachwood NJ
    I am not sure it is the right valve to use in this application but it looks like an automatic expansion valve (AEV). It doesn't control superheat just downstream (evaporator) pressure. Sporlan ADRI
    In an infinite universe, not only are all things possible, all things are necessary
