Results 1 to 10 of 10
    Jan 2012
    Baltimore, MD
    ez-in mini split cable
    Planning on using the nylon jacketed ez-in wire for an install, what connectors do you guys use for the outdoor unit ? Talked to salesman at Johnstone he had no info on specific connectors to use in wet location any help is appreciated
    May 2017
    Quote Originally Posted by bbishoff06 View Post
    I clean installations up using weathertight j-boxes, bushings, and flex conduit. anywhere there is any possibility of a junction coming in contact with water, dialectric-filled connectors. The fewer the connections, the better, but at entries, it is good to have a box and serviceable connection in an enclosure.
    Sent from my SM-N930V using Tapatalk
    These http://www.graybar.com/store/en/gb/1-2-inch-zinc-die-cast-mighty-seal-mc-teck-cable-connector-with-pvc-jacket-25069996#{KO%20Size%20(Inches):1/2%20in.}&{Trade%20Size%20(Inches):1/2%20in.}&{Additional%20Features:MC%20Cable%20Range %2012/2%20to%2010/3,%20TECK%20Cable%20Range%2014/2%20to%2012/2}
    Someting wong https://www.elliottelectric.com/P/Item/BRI/595DC2/
    May 2017
    http://www.elecdirect.com/liquid-tig...RoCK94QAvD_BwE
    May 2017
    Quote Originally Posted by nrusnell View Post
    https://m.grainger.com/mobile/catego...catalog/N-18nr
    May 2017
    https://www.heyco.com/Liquid_Tight_Conduit_Fittings/
    still no worky
    These http://www.graybar.com/store/en/gb/1...CK%20Cable%20R
    Worky!
    Southwire, the makers of "ez-in" have connectors available.
  9. Likes ckelley3, kdean1 liked this post
  10. #9
    Sep 2012
    Cincinnati
    The connectors are crazy expensive. I run 14-3 UF on all my mini installs and put it in FNMC to protect from physical damage on any exposed length on the exterior.
  11. Likes nrusnell liked this post
  12. #10
    Sep 2017
    Southwire recommends (and my local inspector looks for):
    Zinc Die Cast:
    Bridgeport cat. no. 595-DC2 = straight connector - ⅜" trade size / " ko
    Bridgeport cat. no. 895-DC2 = 90 connector - ⅜" trade size / " ko
    Bridgeport cat. no. 596-DC2 = straight connector - " trade size / " ko
    Zinc Die Cast with Insulated Throat:
    Bridgeport cat. no. 595-DCI2 = straight connector - ⅜" trade size / " ko
    Bridgeport cat. no. 895-DCI2 = 90 connector - ⅜" trade size / " ko
    Bridgeport cat. no. 596-DCI2 = straight connector - " trade size / " ko
    Polyolefin Coated / Direct Burial / Harsh Environment:
    Bridgeport cat. no. 595-DC2C = straight connector - ⅜" trade size / " ko
    Bridgeport cat. no. 895-DC2C = 90 connector - ⅜" trade size / " ko
    Bridgeport cat. no. 596-DC2C = straight connector - " trade size / " ko
    Image link (add "https:" to this address-> //imgur.com/a/QQEVC
