Page 4 of 4 FirstFirst 1234
Results 40 to 51 of 51
  1. #40
    Are ou getting the Mod control?
    With a heat loss that low, can't see you needing a steam humidifier, but its possible.
    Yes, doing the mod control, our place is crazy dry during the winter and our current humidifier seems to be meant for show.
  2. #41
    Over sized furnace doesn't run long enough for it to work.
  3. #42
    Toledo, Ohio, United States
    Twilli says great choice
    No Heat No Cool You need Action Fast
  4. #43
    Houston,Tx.
    Mr. Bill ask's how long does a furnace have to run before it works.
  5. #44
    LOL...
    You had to read the humidifier discussion too, to understand that one.
  6. #45
    Twilli says they got some kind of new stat coming out that is supposed to have some enhanced features,,
  7. #46
    Rochester NY
    BEENTHERE makes a point you didn't pursue very far.
    You should not need a humidifier for such a small space. Indicates you have way too much leakage. You are already loosing too much moisture, a humidifier is likely to create durability/rot/mold issues.
    Air seal the place. Reduce your energy bill, drafts, furnace wear and tear, increase comfort...
  8. #47
    Quote Originally Posted by tedkidd View Post
    So you're saying I should get UV and ozone installed as well.
  9. #48
    Rochester NY
    Quote Originally Posted by milicz View Post
    Mmm, no. I believe uv lights are energy wasting placeebos.
    Air seal your home.
  10. #49
    Before:
    http://picasaweb.google.com/lh/photo...eat=directlink
    After:
    Thanks for everyone's help!!! The furnace is TONS quieter, the modulating works great, any comments on the install? It took two guys 13.5 hours to do.
  11. #50
    Dec 2012
    This is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise here. Please apply to the AOPC today, thank you.
    Further infractions may result in loss of posting privileges.
  12. #51
    larryon38, this is the Ask Our Pro's forum, and only Pro members that have been vetted by the AOPC may post advise, commentary or ask questions of the OP here. Please apply to the AOPC today, thank you.
    Your post has been deleted.
    Old thread, thread closed.
