Results 14 to 18 of 18
    Cleveland, OH
    I'm not sure what I was thinking of but you guys are correct. Sheesh.
    Good? Bad? I'm the guy with the gun.
    Statements made by me are strictly my opinions and do not reflect the opinions of my employer. I am not authorized to make any official statements on behalf of my employer.
    Any technical advice offered by me is for educational purposes only, all HVAC related repairs should only be attempted by qualified personnel.
  2. Likes Mr Bill liked this post
  3. #15
    in a house, Appomattox, Va.
    someone mentioned crossover flex, may want to check that oif its a double wide. had one this week, could feel a little air out ducts on one side house, went under it and huge critter hole in side of flex.
    Col 3:23
  4. #16
    Aug 2017
    76 most of the day in the hallway today, got to 77 for a little bit though. Quite a bit more comfortable in the house though. Tomorrow my brother and I are crawling underneath to check the ducts.
    Duct temperature is 67 degrees, I set the thermometer on the air filter and it read 82 so a 15 degree difference.
  5. #17
    Quote Originally Posted by Nick1994 View Post
    Does it have one of those 6" fresh air ducts through the roof? If so blank that stupid thing off.
  6. #18
    Aug 2017
    No fresh air ducts in the roof.
    Today my brother and I crawled underneath the house, it is lined with fiberglass insulation up under the floor. Under that is the hard metal ducts. There is 1-12" insulated flexible duct that runs to 2 vents across the house about 15'. Right in the middle of it it was broken in half just blowing cold air under the house. My brother and I used a ton of duct tape and got it matched up real good, turned the a/c back on and it blew the flexible hose off where it meets up with the hard steel ducting. The idiots who put all this together didn't use an elbow, they stretched the already too short flexible duct in a 90 degree bend which caused it to break over time. Went to Home Depot and got a 12" 90 degree elbow and another one that's adjusted straight to give the hose some slack, used sheet metal screws and aluminum tape to seal it up and it's really strong, no more leaks.
    This winter we will probably replace the flexible hose, it's just too hot to be doing it and have the a/c off in the meantime.
    We'll see how it does this week, thanks for all the help guys.
  7. Likes HVAC_Marc liked this post
