Results 1 to 13 of 21
Thread: Hilmor VCRT
    Frown Hilmor VCRT
    Anyone know if these are better than Appion at core removal?
    Does the magnet do anything other than stick to the unit for storage?
    I am failing more then succeeding with removal and the Appions. I have 4 of their tools and 2 more gripper portions and still have issues. They unscrew, just don't seem to be able to grab hold of the core.
    I saw a tool in a supplier that is for core removal and it has an end that is spring loaded and grips the ball portion of the core. I wonder if this could be incorporated into the VCRT of Appion, YJ, Hilmor, etc?
    Mar 2014
    Grand Blanc
    I also have the same issue with my appion. It takes me two to three try to remove the core.
    Sent from my HTC One_M8 using Tapatalk
    Aug 2015
    Buffalo,NY
    I actually called Appion about this. Same thing happens on both of mine. I've actually needed to use the pressure to blow the core out on more than one occasion. I was told that I'm compressing the oring to much by over tightening. I asked them if it's over tightened how is it that it still swivels on the service port. Dead silence on the other end.
    Chicago area
    Quote Originally Posted by Metalman0880 View Post
    I wonder if the theory is that the core itself gets stuck on the compressed o-ring. I guess that makes sense. Im gonna test that.
  5. Likes Metalman0880 liked this post
  6. #5
    If that's the case, then I need to get word to the mfrs. Most of the time it is on new equipment.
  7. #6
    Chicago area
    Quote Originally Posted by pacnw View Post
    Not the core being too tight, but the core tool.
  8. #7
    If they don't grab I wonder if filing the grabber end shorter would help. The two fork fingers might be bottoming out on tight stem heads where the tool plunger just pushes the valve open.
  9. #8
    Akron
    I did buy a couple of the Hilmor units, vacuum wise they are rated at 20 microns, as far as the core grabber, it is solid, it is a wedging type grabber that grips the edge rather then the core depressor tip. See the attached photo.
    JLB,
  10. #9
    Quote Originally Posted by heatingman View Post
    You are saying the o-ring in the vcrt gets squished causing an obstruction?
  11. Likes Metalman0880 liked this post
  12. #10
    Aug 2015
    Buffalo,NY
    Correct. That is what I was led to believe from tech support at appion. Like I said though my vcr's would easily swivel on both access ports and I had the same trouble with both. If it was only 1 I could understand. Just sounds a little far fetched for both though. It is possible the fork it self may be to long as stated above.
  13. #11
    Chicago area
    Thats my interpretation of what Appion told Metalman on the phone.
  14. #12
    NH
    Like Jim said the hilmor is a little different, it grips the edges and is a little harder to tell when you have it lined up to push it on the core. I've only used it a couple of times but so far so good, just takes some getting use to. I also have had bad luck with my appions. I've even had the replacement stem piece from appion.
  15. #13
    Jun 2013
    Northeast Wi
    How have these been when pulling a vacuum? I think I'm have some issues with the appions during a vacuum.
    Life is tough, but is tougher if you are stupid
    -John wayne
