Results 1 to 13 of 14
    Confused Heat N Glo Intellifire Plus remote, anyone else frustrated by it!!
    http://www.heatnglo.com/Owner-Resour...ss-Remote.aspx
    We have installed a few of these lately and this remote seems to have way too much crammed into it. They are using this single remote for their basic model to full featured model. Options are on the remote display even if they are not in the unit.
    With options, try to program them and you have to do so in each of 3 operating modes.
    Then if the unit is used as a heat source(per HnG, it is not meant to be used as such) there is a 7 hour timed function that shuts it down. This also wipes the settings.
    Program the light and pilot to stay on all the time. Lose power or don't use the unit and the lights turn off, pilot stays on.
    Switch modes and lose the lights, pilot stays on.
    To me it is as if there is an issue with the programming in the remote, but there are 2 in one house that do the same. Tech support, had 3 different people tell me slightly different things, says it's all sounds correct.
    My opinion is they need to have matching remotes for options in their units. Simple remote for simple. I realize they are cutting costs by making a universal remote, but we all know universal means trouble. It does too many things okay and not enough things well and some things poorly.
    Rant over.
    Mar 2013
    Billington Heights, NY
    time to switch manufacturers?
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
    Quote Originally Posted by HVAC_Marc View Post
    To who?
    Said that to the resi sales guy.
    Mar 2013
    Quote Originally Posted by pacnw View Post
    To who?
    kozy, heatlilator, majestic, etc. or anyone else not associated with ht-n-glo company
    im sure a Google search can turn up one or two in your area?
    Jun 2017
    I am a huge fan of HHT products (Heat N Glo, Quadrafire and Heatilator). Not a big fan of Proflame (Kozy and Mendota). When you do fireoffs, tell customers to not use thermostat mode unless its their main source of heat. Other than that all the options are pretty straight forward and none of my customers complain. If they do its easy to help them through a phone call, if you know the product thoroughly.
    This particular customer does use them for primary heat.
    The set up seems easy, just the operation. It's especially tricky if someone else touches the remote or there is a power outage.
    Jun 2017
    If they don't use it for primary heat, tell them to use the remote as an on/off switch. Set the fan on low and teach them how to use the stepper motor.
    Menu>Up/Down>Select>Up/Down>Select.. its pretty simple. In the event of a power outage use the battery backup tray to power the IPI/IPI+ Module. Tell customers not to leave the batteries in the tray year around. I always leave the battery tray near the gas valve so the customer can see it easy.
    Pilot icon is a snowflake. Tell them if its below freezing -- hence the snowflake, leave the pilot light lit
    S.E. Pa
    Heatilator and Majestic are owned by HHT.
    Quote Originally Posted by FreeThrowGuy View Post
    I know how to use it and set it up. It's just not common sense to use.
    Jun 2017
    Are you a contractor in Phoenix?
    S.E. Pa
    The hearth industry as a whole went to he** in a handbasket in 2006. The economy took a dump and mfrs. responded by slaughtering their technical staffs. The old timers who know what works, how things work and what doesn't have been run off. Most mfrs. don't maintain a viable technical services dept. instead directing people to their local dealers who have zero training or support on matters above the most basic installation requirements. It is a sham. People have real issues with nowhere to turn.
    HHT is the largest fireplace company in the world. They just bought VT. Castings/ Majestic/ Monessen to add to their stable. All they do when they acquire other brands is load the pdf files for brochures and installations and email these out like candy. There is no connection to the engineers who designed and tested their crap appliances.
    I went to pull the convection blower on a wood stove insert yesterday. It was a major brand. After 2 hours of disassembly there was no visible way it was coming out. No technical support from the mfr. either online, by phone or through any local dealers, who are clueless. The blower with the supposedly "permanently lubricated bearings are dry and squeaking just months outside the warranty period. It is a known defect with this product. The technician must annually lubricate the felt pads in the permanently lubricated bearings.
    Some mfrs. flat refuse to open their training to non-dealers. Meanwhile, without a viable dealer to support the existing inventory installed, homeowners are forced to hire service techs who do not have access to service information, the mfrs. tech support, or parts.
    It is only a matter of time before this goes to a federal court on a challenge to the Magnusson-Moss Act regarding warranties. Meanwhile, the homeowners, dealers and service techs are left in the lurch.
    Meanwhile, ongoing litigation and regulation by corrupt agencies is depleting what limited resources this industry has to fight regulations that are onerous, malicious and capricious. The industry is, therefore, very weak.
    No, I'm not proud of the hearth industry at the moment.
    Apr 2017
    Canada, BC
    We used to sell Majestic, but just before the sale to HHT their "Patriot" model messed us up pretty bad. The programming on the board was actually incorrect for the IPI unit, and to my knowledge it was never fixed. We got lucky and converted all the units we had sold to standing pilot units, but three board revisions later it still hadnt been fixed, and then the company was sold and all their existing models using their various IPI systems were discontinued and re-released with the new owner's controls. It's actually exceedingly difficult to even find the manuals for the majestic units now, and some are under two years old. We actually had a VP and a senior tech fly out to our little city to help me diagnose the problem, but ya - never fixed. I'm surprised nobody here was burned by that unit.
    Personally I like the skytech control systems (especially with the release of the thermocouple based IPI system) even if the remote is a bit cheesy. I also like the proflame systems, although I preferred the proflame I over the proflame II. I find in general outsourced control systems are a better idea than proprietary for getting support on products, as we have several manufacturers who use the same systems, but the primarily brand we sell that uses proflame builds them literally right down the street from us which helps too
    Aug 2017
    I have had a couple of customers complaining of phantom remote issues. Specifically an issue with a delayed ignition while the homeowner was on the other side of the house. She swore to me that the remote was not in thermostat mode and the fireplace turned itself on. Tech support was at a loss for an explanation. Tech support admitted that the remotes can be interfered with from other house hold items. New remote and receiver was supplied by Heat N glow under-warranty.
