    Jul 2017
    RTU replacement affects control system
    Hello,
    I am new to this community and have no knowledge of HVAC, but have been put in charge of overseeing the cost analysis and eventual replacement of our HVAC RTU. Here is my current dilemma: We have 17 year old 50 Ton Trane Intellapak RTU with an outdated Trane Tracer control system. I am wondering if I replaced our RTU with a different manufacturer such as Carrier and we added the Carrier control system would this control system work with our existing VAV's or would there have to be a board replacement on each VAV? Thank you in advance for any help and assistance.
    Southeastern Pa
    I think you need a greater level of in-person advice then you can get from any website.
    There is more to your situation than you may realize. A 50 ton Trane intellipak sits on a roof curb which matches the placement of the ductwork that it serves. Carrier likely does not manufacture a unit which will sit on that same curb and meet the same footprint requirements of your duct work. Now....you're talking about either using a curb adapter (which raises the height of the unit making it more difficult to service and introduces resistance to airflow) and as to whether or not your VAV system would work with a different brand...I would say the most likely answer is no, since you're using Tracer, most likely your VAV boxes are designed to work with the Trane control system.
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
    Jul 2017
    Yes a curb adapter would be required if we switched away from Trane, which raises the unit about 14 inches requiring us to install additional screening. I was worried that the VAV system would be an issue. We had a contractor that said the Carrier BACNet might be able to work but I was a little unsure. Thank you for your help.
    Southold, NY
    I think Might Work sends some red flags flying!
    Jul 2017
    That part made me nervous as well which is why I came here!
