Results 1 to 4 of 4
    Aug 2018
    Lochinvar Knight/ and or Nobel
    Which is a better unit and why
    Mar 2013
    Billington Heights, NY
    There is no better unit.
    This forum requires that you wait 20 seconds between posts. Please try again in 50 seconds.
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Pecmsg - "NEST should only be used with 3-M filters to guarantee total destruction of the equipment!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
    Oct 2009
    God's country - Shenandoah Valley, VA
    The Knight is a space heating boiler, the Noble is a Combi that does both space and domestic heating. Both are excellent boilers, but you better concentrate on finding a COMPETENT hydronic contractor. They're 98% of the equation and few are far between.
    Also, the Noble may look like the better bargain, but a combi that is of sufficient size for domestic is almost always way oversized for space heating and will require the addition of a buffer tank to keep it from short cycling to death. A boiler that's PROPERLY sized for space heating + an indirect water heater is usually the best choice.
    Bob Boan
    ​You can choose to do what you want, but you cannot choose the consequences.
    Aug 2018
    When you say an indirect water heater does. that mean, like the Squires sit 050 ?
