Results 14 to 22 of 22
    Quote Originally Posted by heatingman View Post
    Thanks.
    I would like to mention that its becoming more and more common to see different refrigerants in different circuits.
    Meaning circuit 1 has a new compressor, and as part of that - circuit 1 is now 407c, and circuit 2 is still R-22
    So for multi circuit/unit mode it would be helpful for refrigerant selection to be independent per circuit/unit.
    Good point!
    I recently worked on a 4 circuit Lennox L-Series package unit that had a different refrigerant in each circuit!
    Did some testing on my own system today, guess it is doing ok.
    Akron
    I very rarely do much service anymore, but my old neighbor moved out and a new one in. The old neighbor almost never used the air. I was going to mow the grass, and I can hear the condenser running and then hear the furnace start, and then the internal bypass openss on the compressor due to the heat about 2-3 minutes later.
    I went over an about an hour later we had removed a basement thermostat that was wired in parallel with the main, cleaned the condenser, removed 2 lb of R22, and opened all of the dampers to the second floor that were shut, and cleaned the drain. As well as dropping the fan speed four speeds from high to low.
    To say the least, it was a mess. I am guessing that in 20 years it was never on. It had a 10-degree split and was running at 58% of its total capacity and doing almost no latent cooling.
    To top it off, they had the "home warranty company" there the week before, the home inspected and passed, had a contractor out the day before, and no one picked up on any of the issues. If I could have, I would have made them all come back for class.
    JLB,
  5. Likes Steve Max liked this post
  6. #18
    Jun 2012
    Northeast
    Question
    Does the measure quick work with the JL2? I cannot find them when scanning for new devices. I am using the SMAN460 and SDP2. Please, please, please don't say no
  7. #19
    Akron
    Quote Originally Posted by Push It View Post
    I was just talking to FP about that today. It does not as of yet, but I am sure that it could work. I would suggest that you contact FP and let them know there is interest.
    JLB,
  8. #20
    Jun 2012
    Northeast
    Quote Originally Posted by jim bergmann View Post
    Ah crap. I have contacted them a few times. Don't want to beat a dead horse. Keep up the good work Jim I appreciate what you bring to the industry.
  9. #21
    VA
    Damn! Now, I gotta buy these probes just to test them out. If the range and accuracy is really that good. How could you go wrong with use of the Measurequick app?
    "The only true wisdom is in knowing you know nothing" Socrates
    Visit us at Dr. Degree°s HVAC
    or like us on Facebook
  10. #22
    Deep Southeast
    The latest version sees my iConnect, but not my (iManifold) probes. It crashes on my tablet (but not my phone - but can't see probes on either device). Start app first, then iConnect & probes, see iConnect but not probes. Start probes/iConnect first, then MQ app, see iConnect but not probes. Others have had same issue.
