    Chicago area
    Rtaa200 exv board (1u3) valve power supply
    Ive got an existing board that no longer supplies the 25 to 30vdc to the valves.
    I picked up a new board, but obviously something killed the original.
    Can I use a 30vdc external power supply and use the old board to do the step control to test if one of the valves is bad?
    Or is there a fuse (what amps)I can put inline with the power feed to the exv’s to prevent overloading and wrecking the new board?
    up in the hizzy
    Perfect opportunity to justify the purchase of the SMA-12, I got mine from United for $230
    There is not better place for the working men than the union! 100% UA the only HVAC union!
    Chicago area
    Quote Originally Posted by valdelocc View Post
    What is the sma-12?
    I assume a exv test tool?
    Is it compatible with the Sporlan SEO-100?
    Chicago area
    This is what sporlan shows on the parts list
    Chicago area
    Just like I thought, that tool is not compatible.
    STA-12 works with the 12v bi-polar and unipolar stepper valves.
    This one pre-dates that. Operates on 30 v power
    And 9 volt phase step signals.
