Results 1 to 6 of 6
    Jul 2018
    Own home install
    3ton heatpump and 95% Bryant. ERV and 3 zone Bryant zone system. For some reason this phone does not like putting pics right side up. Or maybe it should be left side up. Lol.
  2. Likes Metalman0880 liked this post
  3. #2
    Looks good the last picture is how i like wireing to be
  4. #3
    Madison, WI/Cape Coral, FL
    Where in God's green earth is this. Water Gauges and pressure drop meters, Wow.
    The only thing missing is a small whole dehumidifier.
    How do you control the fresh air ventilation?
    Keep us posted on how it all works.
  5. #4
    May 2013
    Kelowna BC
    What's the reasoning/benefit for running a pump down system on the AC? ... assuming that's what the solenoid is for at the CU. Cheers.
  6. #5
    Oct 2014
    Columbus, Ohio
    Quote Originally Posted by Lahrs View Post
    Sometimes the solenoid is required for long lineset applications.
  7. #6
    Jul 2018
    I just like to mess around it's how we learn isn't it. Not a pump down just a drop solenoid due to length of line set. And ERV has it's own controller high end Vanee digital one.
