Results 14 to 20 of 20
    Feb 2017
    New York
    Quote Originally Posted by Dcoursey86 View Post
    That seems to be the consensus. I'll be sure to check that design tag again when I'm there this week. If not there I'll be calling Trane to get the info.
    I can't say I've ever seen a tag, at least in our territory. I usually see it hand written in the door.
    If you need to get them out of danger right away, 75° with a chilled water setpoint of 42° is a safe place to start. Most places I've been to ramp both fans with the same signal.
    Sent from my SM-G920V using Tapatalk
    -----Stop, step back, relax and have another go at it.-----
    Mar 2017
    Orange County, CA
    By design tag I meant a sticker, usually hand written design specs.
    Feb 2017
    New York
    Quote Originally Posted by Chillertech4 View Post
    Ohh, got ya. I usually use a straight edge and a sharpie.
    ottawa canada
    If you post the serial number there are many techs on here that can get the design info in a few clicks of a keyboard ....
    But then we will start that whole debate about salesguys rushing over to steal work blah blah blah ......
  5. Likes JCN liked this post
  6. #18
    Mar 2017
    Orange County, CA
    I have a good friend who worked for trane Los Angeles. I asked him about that and he started laughing at me, I didn’t believe it anyways. Even if the salesman did go, I’m confident in my work....plus every other contractor goes after every account anyways...
  7. #19
    The Hot South
    Does the chiller have a refrigerant pump? If so, you can run the tower water pretty cold. Down to 15 degrees above chilled water. You don’t want to run condenser water above design temp but you can run it below design temp. If you have an AFD, you won’t get the full benefit of it unless you have tower relief.
  8. #20
    Mar 2016
    Marengo, IL
    Quote Originally Posted by BennyD View Post
    Yea, thats what I meant by tag. Unfortunately at this site the tower fans are not on drives, simple on/off.
