Results 1 to 7 of 7
    Dec 2014
    Carrier 2 ton - need recommended indoor piston size
    Carrier 2 ton
    Model # 25HCB324A300
    S # 0609E01220
    Jul 2018
    SeaTac WA
    You can probably call it the carrier tech support for that if it's a really long mine said it will be a different orifice size recommendation. It was over a hundred feet it'll be different than what comes for with it with a 2-ton coil. You can always put it expansion valve in there. If you can get a PDF on the condensing unit and the air handler it might be in there also that orifice that you need
    Sent from my SM-J700T using Tapatalk
    Jul 2018
    SeaTac WA
    Do a Google on your model numbers of the air handler and the condensing unit and see if you can get a PDF if not get ahold of carrier
    Dec 2014
    Have a update—
    Carrier tech support called and back and said, 56 or 57 - depending on what indoor coil it is.
    Quote Originally Posted by hvac1993 View Post
    Carrier 2 ton
    S # 0609E01220
    Product Data manual stated - #57 indoor piston and #46 outdoor piston (heating).
    If you want the manuals, let me know and I will email them to you.
    Dec 2014
    Quote Originally Posted by rundawg View Post
    Dec 2014
