Results 1 to 6 of 6
    Mar 2018
    Heat pump intermittent cooling
    Hello, so I replaced the compressor on this heat pump and now it comes on and off basically whenever it wants. The pressures are 75 suction 220 head, on a 88 degree day. It will run normal for 40 minutes then everything shuts off. 5 minutes later it’s coming on again, mind you it never satisfied the tstat. Any help?
    Nov 2010
    Cincinnati, OH
    Wheres the voltage dropping out when it shuts off? The whole system indoor and out door shuts down? I can think of a few things that would cause it to do that. Your meter is your friend.
    Southold, NY
    What killed the old pump?
    May 2018
    Knoxville, TN
    You mean we should find out why the old pump died before we replace it?
    Dec 2003
    Citrus County, Florida
    Quote Originally Posted by Thassel8 View Post
    That would be a good thing to do or at least have an educated reason.
    Doug
  6. Likes Thassel8 liked this post
  7. #6
    Southold, NY
    I know a radical idea!
  8. Likes Thassel8 liked this post
