Page 3 of 3 FirstFirst 123
Results 27 to 31 of 31
  1. #27
    Jul 2010
    napping on the couch
    Quote Originally Posted by BBeerme View Post
    Yeah, I use the mega hoses also. Then I hook up my charging manifold/hoses to the core removal tools. Then I burp the air out of the hoses before charging.
    As mentioned in post #12, I couldn't figure out how to purge the hoses with the low loss fittings attached to the hoses. I had to put the low loss end of the hose on the manifold just so I could purge the air out of the hoses.
    I usually take the refrigerant tank and the center hose from my manifold(without the low loss fitting) and weigh in the charge through the CRTs. If it's a split and I don't know the exact charge I'll put in the factory charge from the outdoor. Then start the unit and hook up gauges normally to finish charging.
    It goes in quick because it's just one hose. No core depressers. No schrader valves. No manifold.
    I've used the ball valves before. I just prefer to keep my gauges streamlined. The valves get in the way. Get snagged on things. Open up by accident. Take up room when your packing things up to the roof. My low and high side hoses are JB Kobra low loss and the center is a normal hose with depressor removed.
    “Free men do not ask permission to bear arms.”
    -Possibly said by Thomas Jefferson(but true even if he didn't)
    “What one generation tolerates, the next generation will embrace.”
    ― Definitely said by John Wesley
    "One out of 3 Democrat voters is just as stupid as the other two"
    -Said by me
  2. #28
    Jul 2010
    Quote Originally Posted by RMSG01 View Post
    The only way I have found to purge the low loss fitting hoses is by using my pocket screw driver to push down the inside to allow the purge, I have seen other guys that used an adapter to purge, but thats just another thing to keep up with, in a box, that will eventually get lost in the grass on a late night running installation scenario, which is why I used my pocket screw driver. LOL
    When you keep your center hose a normal hose you can vent the refrigerant or air out of both sides if there is pressure in the system you are working on. The only time you would hook up to system with no pressure and had to add refrigerant is if you just evacuated. Then I do as described above. There may be times when there is zero refrigerant pressure in a system or even the suction side running in a vacuum. If that's the case, the tiny bit of a different type of refrigerant it may pull in is th least of the systems problems.
    Before I hook up my hoses I purge any refrigerant pressure out of the high and low out the center hose. Which usually isn't much because I almost always pull any refrigerant back into the system I'm working on though the suction side when I'm done.
    -Said by me
  3. #29
    Mar 2013
    Port St. Lucie, Fl
    I have normal hoses with the ball valve adapters on the high side and middle hose ends.
    Having a ball valve on the high and center hoses gives me a chance to easily measure a pressure drop across things like filter driers while using the same (high side) gauge and without having to disconnect and reconnect hoses to the system.
    Sent from my Moto Z (2) using Tapatalk
  4. #30
    Nov 2016
    NYC
    Nobody uses analog anymore.. so 1990s... get the YJ digital manifold
    Sent from my SM-G930T using Tapatalk
    HVAC Magician @ UA Local 638
  5. #31
    May 2014
    Bay Area California
    Quote Originally Posted by BALloyd View Post
    Just keep a 1/4" flare fitting handy to screw on the LL fitting briefly to purge.
    Sent from my SM-N910W8 using Tapatalk
    Oh, yeah, I guess that's what I should've done. I got my way of doing things which has been streamlined for quality and accuracy. Just threw me for a loop using a brand new set of gauges from a new hire rookie.
