Results 1 to 8 of 8
    Dec 2015
    Austin
    Running heater when outdoor temp are in the 90sF
    Got a nasty VOC issue and I need to do a bake out. https://tinyurl.com/ybwmga2m
    I'm in central Texas with temps in low to high 90s with dew points between 69 -73.
    Want to get the indoor temps up before using out side ventilation to keep indoor RH<60.
    Question: Can I run the heater of my heat pump when out door temps are in the low to mid 90sF.
    My starting indoor temp will be in in the low 70s at about 45 - 50 RH. I'm concerned about damaging my heat pump.
    Mar 2013
    Billington Heights, NY
    Wasnt the Molekule supposed to take care of this? What happened with that?
    You can run the heat strips but not the heat pump.
    Stop making duplicate threads, it's frowned upon here.
    This forum requires that you wait 20 seconds between posts. Please try again in 50 seconds.
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Pecmsg - "NEST should only be used with 3-M filters to guarantee total destruction of the equipment!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
  3. Likes DavidDeBord liked this post
  4. #3
    Dec 2015
    Austin
    Quote Originally Posted by HVAC_Marc View Post
    Ask you buddy kmartin78, he seems very pleased.
    My latest resulted were posted months ago.
    Stop responding with bating negative responses - That's frowned Everywhere - including here.
  5. #4
    Mar 2013
    Quote Originally Posted by randyf View Post
    His doesnt work either. Even the whole house proto-version. Since you have more accurate and expensive testing apparatus I figured you might have better results of the testing.
    Were your results lost in the crash? Last I heard you were waiting for a re-calibrated testing tool.
  6. #5
    Dec 2015
    Austin
    Really. Was that a private conversation between you and him? His last post, that I'm aware of, was full of superlatives for the device.
    I don't *have* testing apparatus I rent them - Just like Keith talked of doing and you or anyone else can do.
    [QUOTE}Were your results lost in the crash? Last I heard you were waiting for a re-calibrated testing tool.[/QUOTE]
    Some of my post were lost in the crash but they've been summarized since the crash.
    [/QUOTE]
  7. #6
    Mar 2013
    Yes, it was a phone call actually. It hasnt proved itself.
    I don't *have* testing apparatus I rent them - Just like Keith talked of doing and you or anyone else can do. Some of my post were lost in the crash but they've been summarized since the crash.
    Rent, have, use... it's all the same in the results. Right?
    I'll have to go back and read the results at some point. I must have missed them.
  8. #7
    Dec 2015
    Austin
    I'd be curious what Keith's latest impressions are. Last time he posted he was overflowing with accolades about the MoleKule.
  9. #8
    Mar 2013
    He hasnt been around in a long time. Last I heard he spent the dollars for his new metal ducting and had the new system installed. Then he was side tracked with other unrelated issues.
