Results 14 to 25 of 25
Thread: DIY A/C Install
    Mar 2013
    Billington Heights, NY
    Quote Originally Posted by RMSG01 View Post
    Just curious, did he use MAPP gas? LOL
    brazing with MAPP/Pro is easy. It just takes longer.
    This forum requires that you wait 20 seconds between posts. Please try again in 50 seconds.
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Pecmsg - "NEST should only be used with 3-M filters to guarantee total destruction of the equipment!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
    Aug 2011
    Lewes, DE
    shit worked..just saying
    Jul 2018
    NW Louisiana aka Hell Pit of Louisiana
    Quote Originally Posted by HVAC_Marc View Post
    I have done it before, it worked, and I have done larger size pipe as well, with two mapp oxy kits, one had a dual tip, so I had 3 points of heat on the pipe, it finally got hot enough to melt the 15%. This was an after hours, back in the day, emergency repair when no one opened for no amount of money after the door was locked for the day.
  4. Likes HVAC_Marc liked this post
  5. #17
    Aug 2011
    Lewes, DE
    mapp burns hotter than acetylene...
  6. #18
    Nov 2008
    Long Island NY
    Think you have it backwards
    Quote Originally Posted by Gross View Post
    Sent from my SM-G965U using Tapatalk
  7. #19
    Aug 2011
    Lewes, DE
    from what I remember it's not the temperature of mapp that is the problem, but the hydrogen content. leaves the joint prone to cracking
  8. #20
    Mar 2013
    MAPP in air is 3670F
    MAPP in oxygen is 5300F
    MAP/Pro in air is 3730F
    MAP/Pro in oxygen 5200F
    Acetylene in air is 4622F
    Acetylene in oxygen is 5612F
    Old MAPP gas used propadiene. The company that made it stopped in 2008. MAP/Pro uses propylene gas. It may leave a residue on some surfaces such as glass.
  9. Likes rjk_cmh liked this post
  10. #21
    Quote Originally Posted by GenesisRefrig View Post
    Yep, the homeowner claimed all the credit for the work.
    If the homeowner did the torchwork, then I wonder who charged it up? I haven't run into this yet, but I wouldn't charge a system like that. I wouldn't want to be associated with it in any way.
    Carpe Carp~ Seize the carp
  11. #22
    Aug 2008
    Hibbing, MN
    The homeowner charged it up. He had a tank of R22 sitting there
    If God didn't want us to eat animals... He wouldn't have made them out of MEAT.
  12. #23
    Run away! Run away!
  13. #24
    Jul 2018
    Actually MAPP burns at 2010 celsius, Acetylene burns at 2500 celsius, after adding oxygen to each, it is 2927 and 3480 celsius. Propane is 1967 and 2526 celsius, maybe you got propane confused with Acetylene.
    #'s taken from, The Engeneering Toolbox, website for reference is:
    https://www.engineeringtoolbox.com/f...ses-d_422.html
  14. #25
    Jul 2018
    I do some work for an individual, he has more different freon and refrigerant than I ever have, he will buy a jug off ebay or where ever if he has ever had to pay a guy to put it in at some point. he actually has a 30 lb jug of R600, because a refrigerator he bought has it in it, just in case it ever needs it... Lawyers pfff.... LOL
