Results 1 to 10 of 10
    Chicago area
    Micro bluvac plus - wireless?
    Does this one have use same graphing app as the pro pus?
    Akron
    Quote Originally Posted by heatingman View Post
    Yes, the features it will not have are the auto pass/fail and leak rate indication. The app, however, is identical.
    JLB,
    Chicago area
    Quote Originally Posted by jim bergmann View Post
    But it will show pass / fail and decay on the app like all the graphs I see posted on this site?
    Akron
    With the micro and the app, you will still be able to determine a leak or moisture by looking at the graph; it will just not automatically determine a pass-fail. You can print the report too. I will try to do a video soon showing the differences.
    JLB,
    Chicago area
    Thanks. I just noticed it on true tech. Is this a new product?
    Looks like the LTE model now has that also.
    Akron
    Yes, all of the BluVacs will now include Bluetooth and work with the app. They will also include a display if you do not want to use the feature. Eventually, the existing style will be discontinued. The application adds another dimension to vacuum, and it helps with identifying leaks vs. moisture. It also provides a means for documentation.
    JLB,
  7. Likes heatingman liked this post
  8. #7
    Portland, Or
    Ordered one last night, looking forward to using it.
  9. #8
    May 2014
    Bay Area California
    Must be why awhile back I noticed a huge price jump; I like the bare bones no frills micro blue vac.
  10. #9
    Chicago area
    Yeah the standard one is up 50%
  11. #10
    Chicago area
    Quote Originally Posted by Steve Max View Post
    Me too, just hope it comes sooner then the possible 10 days.
