Results 1 to 13 of 13
    Nov 2010
    indiana
    Uc freezer trips gfci once a week
    Delfield two door under counter freezer with intermittent tripping 20 amp gfci, scratching my head, first time I cleaned the condenser fan blade and plastic cover near fan, coils were clean, unit holds temp, did not find high amp draw on compressor, both fans or defrost heater. Condenser air flow is not the worst Ive seen, not too near other hot equipment, maybe 8 years old unit, start cap is 320 microfarads, my meter only goes to 200 and appears to be over 200. There is a crack in the plastic interior but I think the insulation is there and its not short cycling because of this, is there something obvious or not obvious Im missing? Thanks
    Southold, NY
    Freezers shouldnt be run on GFCI!
  3. Likes 2sac, tmt0269, GenesisRefrig liked this post
  4. #3
    Oct 2011
    Chicagoland Area
    Take it off the gfci
  5. #4
    Nov 2010
    indiana
    Why should a freezer not be on a gfci? They seem to have most of the refrigerated appliances on them in this kitchen even if they are not near a sink/water source
  6. #5
    Southold, NY
    Quote Originally Posted by uffdanow00 View Post
    Electric heaters, water, Steam, Ice ?
  7. #6
    Get rid of the GFCI
    I wish I had a dollar for every one I took out
    Oh wait ... I do !
  8. Likes 2sac, tmt0269 liked this post
  9. #7
    Nov 2010
    indiana
    I appreciate the education, since this is happening after years of operation, would slightly compromised insulated windings in a moist environment cause a ground fault but not a short/ tripped breaker? Im curious as to the local code aside from getting it to work, they have three single breakers tied together at the panel which feed three separate gfci receptacles,
  10. #8
    Southold, NY
    Youve been lucky.
    Now remove the GFCI.
  11. Likes 2sac, tmt0269 liked this post
  12. #9
    Jun 2006
    I talked with my electrical inspector about this issue once. He said "GFCI outlets are required by code, but I cant control what happens after I leave."
  13. #10
    Southold, NY
    Quote Originally Posted by stat View Post
    Thats when the GFCI sticker goes on
    Several manufacturers state NON GFCI circuits.
  14. #11
    Jun 2009
    DFW, TX
    We had an undercounter freezer on a GFCI for years without issue, started tripping once a week, eventually was tripping constantly. Ended up being the perimeter heater around door frame had shorted against the cabinet.
    Sent from my SAMSUNG-SM-G890A using Tapatalk
  15. #12
    Gfci also go bad , and it probly depends on the brand you choose. I carry 3 at all times because if its near water you're Not really supposed to replace it with a regular rec ...
    But i have kitchens who power wash their floors and walls , and ofcourse the guys dont care , and they drench the outlets constantly. Morons.
  16. Likes tmt0269 liked this post
  17. #13
    Nov 2016
    Check all your connections and make them tight. A little bit funky neutral will make you nutz.
  18. Likes The Turtleman liked this post
