Results 1 to 9 of 9
    Jun 2018
    Fireplace Gas Valve Replacement Help Needed
    Hello experts, I could really use some help in determining a repair.
    I have a 25 year old Canadian made Kingsman Industries natural Gas fireplace and it has a White Rogers gas valve in it.
    The gas valve's plastic dial broke on me, and is a bit of a nuisance to turn on and off when wanting to start the pilot and use the fireplace at the beginning of a fall/winter season.
    The model is:
    White Rogers
    36c03U- Type 139 Milivolt system
    I am unable to locate an exact replacement and am not receiving any help from the supplier, other fireplace retailers,being these valves are old.
    I certainly don't want to replace a fireplace because of a broken dial on a gas valve, so I'm seeking help as to what my replacement options are? All the new ones seem to have a lot higher BTU's than this unit, so I'm at wits end
    I've attached photos of the valve and when it was connected.
    Much Appreciated.
    Mar 2013
    Billington Heights, NY
    almost any millivolt gas valve will work, provided it fits. the btus on the gas valve rating are maximum flow. some start at 0 some have a dedicated range. your tech will be able to figure out the correct valve to use. we really cant help with DIY due to site rules.
    This forum requires that you wait 20 seconds between posts. Please try again in 50 seconds.
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
    Jun 2018
    Is the "type" reference just the issue of the valve, or does it indicate anything I should be aware of. I see 36C03U Type 300 and 333's milivot units all over the place just no older units such as mine?
    Much Appreciated
    Quote Originally Posted by HVAC_Marc View Post
    Mar 2013
    the type is usually an OEM code that indicates special functions or makings for specific secondary manufacturers.
    Mar 2013
    the tech can reference W/R document 0037-7349 if he has any questions
    Jun 2018
    Speaking with Technical services at White Rogers Canada, the Type 139 was discontinued in 1998, the 300 discontinues in 2004 probably is the same unit,
    different name.
    I think I can locate a 300 milivolt around
    Mar 2013
    you shouldnt be locating anything. the tech should. you're getting into DIY that this site doesnt promote.
    Nov 2009
    Simcoe, ON Canada
    Have you tried calling Kingsman directly. They are based in Winnipeg MB Canada.
    Jun 2018
    Kingsman
    I called them twice to see if they could be of any help and were of no help, just stating that the valve is 22 years old and didn't have any replacements.
    Won't be buying another Kingsman for sure!!
    Quote Originally Posted by robatnorfolk View Post
