Results 1 to 10 of 10
Thread: Fin combs
    Oct 2014
    Saint Pail, Minnesota
    Fin combs
    Is there anything better than the disposable plastic ones?
    Never used the metal ones, do they rip apart the fins to easy?
    Or is this just something that hasn’t been changed because they’re the best that is made?
    UA Proud Local 539
    [insert some anti-government idea]
    Color of the refrigerant tank does not specify taste.
    Mar 2015
    Medford, N.Y.
    There are several "items"you can use. A flat blade tweeker screwdriver, a procured "butter knife",a sheetrock knife. Then one bent fin at a time gets "straightened out".Insert,twist,slide over and over and over.
    Thats at about 1/16-1/8 of an inch w/ each twist. Most Techs find it is a "mind altering experience" and after an hour or so of this "wax on/waxoff" procedure they tend to get jittery,LOL!
  3. Likes Jettinvr6sc liked this post
  4. #3
    Mar 2013
    Billington Heights, NY
    they're all junk. if the coil is that bad it really needs to be replaced... ive found that straightening them works ok until they're washed. then they just fold over again. the crease in the metal makes it weak and they bend easily again.
    This forum requires that you wait 20 seconds between posts. Please try again in 50 seconds.
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
  5. #4
    Oct 2014
    Yeah I know the act of doing it seems pointless. Just thought I’d ask. Saw one today that looked like they used a salad for to straighten, five years ago. Then used a rake to comb them the next 5 years after power washer didn’t straighten them.
    UA Proud Local 539
  6. Likes HVAC_Marc liked this post
  7. #5
    Oct 2014
    Duplicate
    UA Proud Local 539
  8. #6
    Mar 2015
    Medford, N.Y.
    I do it 'cause it's just gotta be done.
  9. #7
    Nov 2008
    Long Island NY
    I've used Terry's method a few times, it's like punching tubes on a chiller boring as hell. Also had luck using a welders wire brush if it's not too bad.
    Sent from my SM-N910T using Tapatalk
  10. #8
    May 2014
    Bay Area California
    Punching tubes is downright exciting, compared to properly straightening fins!
    http://hvac-talk.com/vbb/showthread....-Yeoman-s-Work
    Quote Originally Posted by Jettinvr6sc View Post
  11. Likes HVAC_Marc, Jettinvr6sc liked this post
  12. #9
    Oct 2014
    Ugh glad we don’t have any chillers or boilers...
    UA Proud Local 539
  13. #10
    Aug 2008
    Hibbing, MN
    I just learned this last Summer. Over 30 years in the biz, and never knew this.
    Use a wire brush from the hardware store. Like the ones used to brush rust off of rusty steel. It takes a firm hand, but, OMG, does it work good and fast! I straightened ALL the fins on a 10 ton rooftop where someone got pressure washer happy in 30 minutes!
    I used it to straighten evap fins that someone folded over on a 5 ton rooftop in 10 minutes.
    To get closer to the edges of the coil, I cut the handle off of mine.
    The picture is kind of what I use, but with more dense tines and the cut off handle.
    If God didn't want us to eat animals... He wouldn't have made them out of MEAT.
  14. Likes Jettinvr6sc liked this post
