Results 1 to 9 of 9
    May 2003
    Charleston SC
    Internal oil filter access plug on Carrier screw compressor
    Does anyone know of a clever way to remove the access plug for the internal oil filter on a Carrier screw? I've put around 300 ft/lbs on the plug and it won't budge. I think somebody put thread locker on it.
    Oct 2011
    South Georgia
    I use a 3/4 drive hex socket into the plug socket. Use a 3/4 drive pull handle, possibly even with a cheater. apply "vigorous" tension and have a helper tap on the plug with a two pound hammer. If that doesn't work, call in a bull gang crew and get serious.
    up in the hizzy
    Carrier is the one putting red loctite on everything, there is bulletin about using a torch to burn the thread locker.
    There is not better place for the working men than the union! 100% UA the only HVAC union!
    Oct 2011
    Upstate NY
    Carrier didn't put loctite on the oil filter plug fitting, but that doesn't mean someone hasn't used it in the past.
    Your best bet would be to use an impact gun and possibly a little heat As well.
    I don't know if you're changing this filter as part of a maintenance agreement with the customer or if you're changing it because you're "going through the motions", but IMO unless there are compelling reasons to change it, don't.
    Wichita Ks
    the last one I did my 800 ftlb impact would not get it loose. I broke a 1/2" break over bar. I then bought a 3/4 allen 3/4 drive, a 52" 3/4 drive break over bar with a cheater. I got it and the threads were clean. no Loctite at all. I even had new ones that I was the first one to replace filters on was extremely hard to get off.
    in a tree looking in your window
    Ditto to the procedures above 3/4 allen head socket, 3/4 drive breaker bar and a cheater pipe has always worked for me.
    If you dont stand behind our troops, please feel free...........to stand in front of them.
    If it has a thread lock on it - heat will break the bond. It says so right in the Loctite Directions. <g>
    PHM
    Quote Originally Posted by coolairman View Post
    PHM
    Dec 2014
    New Mexico
    We had one that we changed filters every year. Had to use the 3/4 inch route every year. The temp change over the course of the year would make them that hard to get apart. I think it is the two different types of metal , cast body and mild steel cap. Would be better if you could pull down to get it loose. At least my belly would be good for something, I could just hang on the breaker bar.
    Mar 2017
    Orange County, CA
    I’ve changed a lot of internal oil filters on the 06N compressors. Same as everyone has suggested, 3/4 hex socket and a breaker bar. I use a 24” 1/2 drive but 3/4 would be stronger. I’ve always been able to break em free, it’s just a pain. The worst part is cranking down with the oil feed line right in the way.
    I’ve never seen any with loctite even tho it feels like it’s on there.
