Results 14 to 26 of 26
    Quote Originally Posted by I Like Tranes View Post
    Someone messed up, that’s what. When you mix a crappy carrier with a homeowner that thinks he install the furnace himself. Just look at the pvc job, the elbow is not up to code
    Unless you want to provide documentation the the contrary, the venting material looks proper.
    Pipe size may be incorrect, but can't tell that from the photo.
    Mar 2013
    Billington Heights, NY
    very few furnaces allowed the use of 1.5" pipe. Some did BUT the sharp vent elbows most certainly put it beyond the specs of 1.5" pipe.
    This forum requires that you wait 20 seconds between posts. Please try again in 50 seconds.
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
    May 2018
    The elbow termination it too close to the furnace, at least for my area it is. idk about the job here, it might be normal for that area. This pic is what they do in my area. not my pic btw.
    Mar 2013
    The air box only requires the pipe be to the cabinet face before the elbow goes on and the installer did that. It matters not that part of the elbow hub is inside the cabinet. It may have been done that way for clearance issues we cannot see in the picture.
    Mar 2013
    I looked up the IOM for the Weathermaker 9200 shown. It allows for vent elbows and some models had allowances for 1 inch and 1.5 inch venting.
    May 2018
    Well, as I admit the picture is incorrect, do you guys get the message? Homeowners think that they can do Hvac stuff themselves, and end up messing up.
    Mar 2013
    Obviously you dont get it. You're assuming that the pic you posted is DIY. It's never been proven that it was. Plus, Ive seen some DIY that is better than some of the larger well known national companies. MANY homeowners are VERY capable of DIY. It's only that this site doesnt promote it.
    Quit while you're ahead.
  8. Likes Pnasty liked this post
  9. #21
    Quote Originally Posted by HVAC_Marc View Post
    X2
  10. Likes Pnasty liked this post
  11. #22
    Oct 2014
    Saint Pail, Minnesota
    I suppose you call a plumber for a runny toilet or an electrician to change your light bulbs? And to Marc’s point I’ve done start ups on DIY mini splits and they were installed neater than I could have done, I haven’t installed more than two. The way you post things makes you come across as a know it all, not in a good way either.
    UA Proud Local 539
    [insert some anti-government idea]
    Color of the refrigerant tank does not specify taste.
  12. Likes HVAC_Marc liked this post
  13. #23
    Jul 2010
    napping on the couch
    I've got a couple of 40K BTU 58MVP's in my house. They allow 1 1/2 vent for 80k BTU and under.
    60K can have up to 35' of 1 1/2" with 4=90s as an example. The install literature actually warns of using 2" if the chart recommends the 1 1/2" pipe size. It may cause "incomplete combustion, flame disturbance, or flame sense lock out."
    “Free men do not ask permission to bear arms.”
    -Possibly said by Thomas Jefferson(but true even if he didn't)
    “What one generation tolerates, the next generation will embrace.”
    ― Definitely said by John Wesley
    "One out of 3 Democrat voters is just as stupid as the other two"
    -Said by me
  14. Likes HVAC_Marc liked this post
  15. #24
    Mar 2013
    Quote Originally Posted by Brian8383 View Post
    The 58MXA is what I looked up. It said much of the same warning-wise. Here's the clip of the 1 inch vent pipe allowance.
  16. #25
    Cincinnati, Oh
    Awww mark, he just wanted to be one of the guys, and you blew his cover...
  17. Likes HVAC_Marc liked this post
  18. #26
    Mar 2013
