Results 1 to 13 of 19
    May 2018
    San Fernando Valley, CA
    Superheat and Subcool on package units.
    How do you guys get a proper measurement when you only have two H and L ports and the lines are inside the system. do you just recover and charge by weight??? I don't see any other alternative.
    Dec 2003
    Citrus County, Florida
    That is the most accurate method. Some units do provide pressures related to temps. Just remember there is no real line lengths so you have to be careful of superheat.
    Doug
  3. Likes Fender60 liked this post
  4. #3
    May 2017
    I always charge by weight according to unit tag for package units can't go wrong
    Sent from my SM-N950U using Tapatalk
  5. Likes OGlad, Fender60 liked this post
  6. #4
    Dec 2014
    midwest
    Youll find on microchannel units that you may have to reduce the charge below factory spec because of head pressure trips.
    Sent from my SM-G930V using Tapatalk
  7. Likes yakexican33, OGlad, DavidDeBord liked this post
  8. #5
    Jun 2011
    NE Ohio
    Quote Originally Posted by OGlad View Post
    remove a side panel and attach a temperature probe to either the liquid or suction line ?
  9. Likes DavidDeBord liked this post
  10. #6
    I'm not sure what your question is - why can't you use the standard pressures and temperatures to calculate SH and SC ? Just put the panel in place as well as you can - it's not like the units are anything like airtight to start with. <g>
    PHM
    PHM
  11. #7
    Jun 2011
    NE Ohio
    Quote Originally Posted by Poodle Head Mikey View Post
    PHM
    there is also a bit of a process involved to make sure you are not introducing moisture to the system when you recover and recharge, not that you cant get everything below 200 microns .... seems much simpler just to check the SH or SC ....
  12. Likes DavidDeBord liked this post
  13. #8
    Phoenix,AZ
    I use a wireless clamp thermometer. And peek into the unit as it's running to get the line temps.
  14. #9
    Southeastern Pa
    I'm not sure what you're trying to ask....are you trying to charge the unit, or are you doing a maintenance inspection?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  15. #10
    May 2018
    It's just kind of annoying, on the newer lennox package units, its hard to get to the L and H side line set. To recharge is a pain in the ass.
  16. #11
    Southeastern Pa
    Okay....just so we're on the same page.....what model Lennox package unit are we talking about?
    2 Tim 3:16-17
    Member, IAEI
    AOP Forum Rules:
  17. #12
    May 2018
    I dont have the model. Its one of my clients that I changed a cap for a few months ago. I didnt really touch refrigerant because the unit was new and the line set was hard to get to. Next time Im there for service, Ill remove the panel I suppose. I doubt she has leaks yet.
  18. Likes hvacskills liked this post
  19. #13
    Apr 2018
    Rhode Island
    If it's a regular account ,drill two holes but enough for gauges!
