    Nov 2014
    Philadelphia area
    3 way diverting valves
    Might be somewhat of a novice question but i dont do much with diverting valves in heating/chilled water systems. I was installing a 3 way mixing valve for a hot water coil and i noticed a note on the instructions that said “all 3 way valves must use a normally closed actuator”. I was confused by that as i was taught all hot water coils should be piped normally open as a failsafe. Can anyone provide any insight on why the instructions would say that?
    Nov 2014
    Philadelphia area
    EDIT: i was installing a 3 way DIVERTING valve. Not mixing
    Feb 2016
    Louisburg Kansas
    You were taught right. The note is wrong. It's a lot better to get too warm than to freeze a building.
    Chicago area
    If they were talking about the actuator, maybe they meant spring return type.
    Where was the note? On a spec?
    Either way, fail safe to heating is best.
    May 2015
    CT
    Let’s say AB is entering valve, A is going to coil and B is diverting from coil or bypass. U could still have a normally closed actuator closing off flow from AB to B leaving A to coil normally open, maybe that’s what they mean.. That’s the only thing I could come up with to as why they would say that. In my opinion, a valve manufacturer shouldn’t care unless they have to put that on there for insurance purposes lol
