    Aug 2014
    fridiar refrigerator leaking
    hello techs,I worked on frigidaire refrigerator in a house few weeks ago it was leaking condensation into the bottom from the vents,I cleaned all condensate lines,it worked for 2days & customer complained it was dripping water from the air vent again,I want to know besides the gasket being bad which are not what else can cause condensation if it was cleaned not long ago,I would like to get some rite direction to fix there issue,thanks
    Southold, NY
    Drain pan cracked?
  3. Likes DavidDeBord liked this post
  4. #3
    Dec 2003
    Citrus County, Florida
    Does it have water and or ice thru the door? If so, it may have a defective water valve located from the rear right side.
    Doug
  5. #4
    Aug 2014
    no water lines or valve connected, so what else do you think can cause leak may be gel between the airvent & drain?not sure
  6. #5
    Aug 2014
    I dont believe its cracked cause I worked on it few weeks back,can any gap between the vent compartment cause condensation biuld?
