+ Reply to Thread
Results 1 to 10 of 10
Thread: Downflow furnace 2 story house.
    Aug 2016
    Oklahoma
    Had a friend of mine complain his upstairs is always uncomfortable in the hot seasons. Saw his configuration and he has ducts in the crawl space for the first floor and then apparently a big supply line coming from the crawl space up to the second floor. This line is located right next to the unit and looks to be cemented in place. So is this a hack job or was this once practical?
    Mar 2015
    Hamersville, Ohio
    Chris,
    You're gonna need to post a lot more Data, than what is in your O.P.
    What size is "Big"? Is there a R.A. Trunk to the 2nd Fl.? What is the Heat Loss/ Heat Gain for the home? What Equipment is being Used, as well as Brand/ Md.#, & Serial #? Etc., etc., etc.
    To save $$$$, would you be wiling to allow Your Friend to stay with you during the "hot seasons"?
    Lol! I'm kidding, but,.... More Data is needed.
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    Mat_15:24 But he answered, “I wasn’t sent to anyone but the lost sheep of the house of Israel.”
    Nov 2014
    Philadelphia area
    Id be willing to bet that there is no return air duct going to the second floor, or if there is it’s undersized
    Oct 2015
    Illinois
    Hack job / common practice? Now a days on new installs they are pretty much one in the same.
    Yes I see installs with a single duct that runs to the second floor usually to attic then flex duct to the rooms. I would call that a hack job, but others call that normal insulation. The downflows with the duct to second floor I see are townhouses, usually on a slab.
    There is only one truly right way to do something, but there are thousands of wrong ways to varying degrees to do it.
    So the question is: If you don't do it right, then how wrong is it going to be???
    Around here MANY 2 story homes either have furnace in basement or downflow on the first floor. 30 years ago there would be 1 big trunkline and both floors would come off it. 2nd floor registers would go up an inside wall in wallstack then 6" round out to the register under the window.
    Lately they run a single duct to upstairs, maybe a 12" or 14" round then spider in the attic to ceiling registers.
    Either way the upstairs is hot in the summer.
  6. Likes DavidDeBord, Chris4u13, Glennhvac liked this post.
  7. #6
    Oct 2015
    Illinois
    For you yougens wallstack is rectangle duct up the wall cavities. Usually 2 1/4 x 12 or 3 1/4 x 10.
    Yep that is the way I did it. Damper in every supply, made the trunk and plenums ourselves. Also the RA used the Joice spaces, and we made "U ducts" for where the RA ran into duct {there were no cutting holes into the top of the ra duct}
    You know they worked well too. Think the current generation need to know you need duct/ pipe volume to get proper air flow.
  8. Likes DavidDeBord liked this post.
  9. #7
    Mar 2018
    Kansas Flatlands
    He never will be happy. Trying to push cool to the second floor is difficult when at the same time heat is rising. Hard to fight the physics of air stratafication. Now throw in the fact that people desire a cooler house (bedroom to sleep) than they used to. Bet they're happy with the heat. This is why the minisplit market is a boom now. "Can you live with it if I can make just your bedroom as cool as you want?"
  10. #8
    Mar 2015
    Hamersville, Ohio
    I've actually had many a home, where Cooling/ Heating the Second Floor Problems were overcome, when the H.O. allowed me to run the proper duct-work.
  11. #9
    Mar 2018
    Kansas Flatlands
    Quote Originally Posted by DavidDeBord View Post
    If we could only convince every builder to allow a 4' x 4' chase from basement to second floor attic, in the very middle of the house. This would solve some issues.
  12. Likes rjk_cmh, DavidDeBord, Glennhvac liked this post.
  13. #10
    Mar 2015
    Hamersville, Ohio
    Oldscroll, I've gotten Builders (New Work),& Home-owners (Remodel or Improvement to the HVAC), to five me "Chases" at several different locations if needed. After I did all of my Calculations, & then took them to the Builder, or H.O.,& also guaranteed that there would be no greater/ no less, than a 3 degree variation throughout the building, most of them were glad to do it. I've used Closets, corners of rooms, & even a couple of times, had a Supply & Return trunk to the Second Floor, on the same wall, & the H.O. boxed those in, & made a Fake Fireplace.
    I've also insisted upon powered vents for the Attack, Insulation improvements, & more, And, when this was refused, I'd add that refusal in to the contract. so as to protect myself at a later date, if they chose to complain.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
