Results 1 to 7 of 7
    Mar 2013
    Billington Heights, NY
    Square D Safety Switch Recall
    This forum requires that you wait 20 seconds between posts. Please try again in 50 seconds.
    Experience - knowing when to get the hell out of the way and plug your ears. "Don't be a sissy. Turn it on!"
    Pecmsg - "NEST should only be used with 3-M filters to guarantee total destruction of the equipment!"
    Poodle Head Mikey - "the world is well populated with the unknowing and the uncaring and the stupid."
    Apr 2004
    MN
    Remedy:
    Consumers should immediately inspect installed safety switches by moving the handle to the “OFF” position. If the power stays on when the handle is in the “OFF” position, contact Schneider Electric for a free replacement safety switch and free service support to install the replacement switch. If the safety switch is not installed and included in the recall, contact Schneider Electric for a free replacement safety switch. Instructions on how to inspect the switch can be found at www.schneider-electric.us/gdss-safetyalert.
    The quote above was copied and pasted from the recall notice. So, if I'm reading this correctly:
    - if the unit is in use, included in the recall and you turn it off and it fails to disconnect power, they will replace it.
    -if the unit is not installed, but included in the recall, they will replace it.
    However, if the unit is installed, included in the recall and disconnects power when you turn it off, they are not replacing it?
    A Veteran is a person, who at some point in their life, wrote a blank check payable to the United States of America for payment up to and including their life.
    Gene Castagnetti-Director of the National Memorial Cemetery of the Pacific in Hawaii
    Oct 2014
    Columbus, Ohio
    I just saw half a dozen of these installed a few days ago, I will have to check the date codes on them.
    Mar 2013
    Quote Originally Posted by doc havoc View Post
    Remedy:
    That's how I read it, too. It's easy enough to say "broken" though.
    Mar 2015
    Hamersville, Ohio
    Just another reason to Check to see if the Power is off at the Equipment, instead of Taking it for granted.
    But it's, Good to see Schneider doing this Voluntarily, ... Unlike our Representatives in Washington D.C.
    Hos 4:6 My people are destroyed for lack of knowledge. Because you have rejected knowledge, I will also reject you, that you may be no priest to me. Because you have forgotten your God’s law, I will also forget your children.
    "You've got to Stand for Something or You'll fall for anything" (A. Tippin)
    We are on a "Man-made Highway to Hell", Our so called "Leaders", Political & Religious, are encouraging The Mushroom like Sheeple to go faster.
    (AC-DC Lyrics)
  6. Likes ga-hvac-tech, HVAC_Marc liked this post
  7. #6
    Mar 2009
    Winnipeg, Manitoba, Canada
    Thanks for posting this!
  8. Likes HVAC_Marc liked this post
  9. #7
    Oct 2014
    Columbus, Ohio
    As a followup, I found that 5 of 7 disconnects installed on that job had a bad date code. So I went to see how the replacement program worked, and apparently they won't proactively replace them, but only if you actually catch them in the act of malfunctioning. Lame.
  10. Likes HVAC_Marc, DavidDeBord liked this post
