Results 1 to 2 of 2
Thread: Stat Wire Type and Install Quirk
    Nov 2010
    Central Florida
    Hi Guys,
    I need to run a new stat wire between the AHU and outside Condenser. Am thinking of running up the outside wall into the attic BUT there is one obstacle in the way - soffits. So two quick questions:
    1) Is it okay to use sprinkler wire instead of stat? I noticed the insulation with sprinkler wire is thicker (both casing and wires) and since I'm in Florida with direct sunlight on that side of the house, it seems sprinkler wire would be a more durable choice for running up the outside of the house. Or is there any reason I should stay with conventional stat wire?
    2) Any suggestions for getting up through aluminum soffits? Is there any technique short of ripping the house apart? First inclination is to just drill (or Dremel) a tiny opening and try to feed fish tape into the attic?
    Thanks for any help,
    Sonic
    Mar 2013
    East Concord, NY
    Make holes with anything you feel comfortable with. If it's not a communicating system any wire 18 gauge and above will be adequate.
    Nest is POO!!
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
