Results 14 to 22 of 22
    We don't put filters or media cabinets against the furnace. We rarely use or reuse 1" filters. Our supplier has a transition made for smaller units that goes from the 14x18 opening to a 16x25 media cabinet. For higher airflow, they sell a 6" basepan, you cut out the side you need air through and they have a transition from the basepan & side of furnace to a 20x25 media. Got 2 waiting to go in this week,
    Our tech rep says we can run up to 1400 CFM with the 14x18 opening so we will also put a Right Angle Air Bear against the side of the furnace. That way the whole 20x25 media has an even flow of air on it. Like this:
    Aug 2009
    Beatrice, NE
    Nice looking install. I have put in a couple Air Bear right angle filters before but my experience has been they don't filter as well. I have had better luck with the RP products. I gave them an option for the RP unit, they went for it at first then changed their mind on it.
    Quote Originally Posted by buttwheat View Post
    Good looking install. I rarely ever see anyone on here ever use base cans why not?
    I use base cans or both sides on any upfow furnace. It’s hard enough to get within TESP range using bottom/side or side/side much less only using one side.
  4. Likes buttwheat, jacob-k liked this post
  5. #17
    Western Wa.
    Quote Originally Posted by BNME8EZ View Post
    Thanks: Ok, I'll bite, what are base cans?
    It is mounting the furnace on a metal box for better airflow and way easier on the knees to service . see below (none of the pictures are mine just random pics of the interweb)
    UA Proud
    "Phfft! Facts. You can use them to prove anything." Homer Simpson
  6. #18
    Caledonia WI
    You've made a huge improvement on air flow by changing the way it's connected into the trunk lines (seems many contractors are far more interested in cash flow than air flow).
    I install a base can on anything over 60,000 btu, but they don't have to be as big as that (you'd hardly ever have head room for a coil).
    It's not what you're capable of doing that defines you, it's what you do on a daily basis.
  7. #19
    Aug 2009
    Beatrice, NE
    OK, I have seen those, just never heard them called a base can. I thought you were talking about something like a pump up for furnaces, like those corner blocks. If I have to raise a furnace to get air in the bottom I use a plywood box or 2x? frame. All of the base cans I have been around are noisy, like it amplifies the sound. That's one of the reasons I put a foam pad under the furnace, to absorb vibrations.
  8. #20
    I use a 6” base so I can get a 20”x25” cutout.
  9. #21
    Aug 2009
    Beatrice, NE
    Quote Originally Posted by billg View Post
    Yeah I really could have made a bunch of money on this job. With the 1/2" pad I put under the furnace the new equipment was the same size as the old so no duct changes were needed to match up to the equipment. I thought about it but couldn't let it go. The new system is quieter than the old one was.
  10. #22
    Aug 2009
    Beatrice, NE
    I have done that before but this wasn't that big of a system.
