Results 1 to 13 of 33
    Mar 2018
    Mechanical Room as Return Air Plenums
    Hello there!
    Hope everybody is doing fine.
    What are your thoughts about using mechanical room as return air plenums?
    Advantages? Disadvantages? Personal experiences? Tips?
    Thanks and have a nice day yall.
    Chattanooga, TN
    NO.
  3. Likes DavidDeBord liked this post
  4. #3
    Oct 2015
    Illinois
    No and against code
    There is only one truly right way to do something, but there are thousands of wrong ways to varying degrees to do it.
    So the question is: If you don't do it right, then how wrong is it going to be???
  5. Likes DavidDeBord liked this post
  6. #4
    Athens, Ohio
    No! And a potential danger to equipment and building occupants!
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
  7. #5
    Mar 2015
    Hamersville, Ohio
    I Agree with the "No"s, & I'm wondering why in the World one would want to do this.
  8. #6
    Oregon
    I saw this done at an Elementary school once with 2 Trane vertical self contains, and the reliefs weren't piped outside, idiots.
    Federal Reserve, stealing your kids futures since 1913
    UA290
  9. Likes DavidDeBord, kdean1 liked this post
  10. #7
    Mar 2018
    I'm from Brazil, local code allows for it and i've seen many. (i'm not saying it's right or wrong)
    Here's an example of this application:
    It's an air-cooled self-contained unit.
    Both condenser intake and relief are ducted outside.
    Mechanical room is next to the conditioned room.
    Return air comes through the grille/register and goes directly into the equipment room. There is not duct connecting return air to the units.
    There is also an outdoor air intake grille/register.
    Above is a printscreen from Trane's product catalog, where this procedure is considered.
  11. Likes DavidDeBord liked this post
  12. #8
    kansas
    Quote Originally Posted by kdean1 View Post
    How is it a danger to equipment? Many new construction uses a common return back to the mechanical room where it is mixed with outside air in where the mechanical becomes a mixing box?
    Honeywell you can buy better but you cant pay more
    I told my wife when i die to sell my fishing stuff for what its worth not what i told her i paid for it
  13. #9
    Aug 2016
    San Diego
    I don't know why you'd do it, but I don't know why it would damage equipment. Granted I've only seen it done with some smaller units in a really old building. Albeit it wasn't in a mechanical room but just to the space above the t grid.
  14. #10
    We spec. that design. The Mechanical rooms are much cleaner, the air is filtered through cheap PSF-1 filter material. Also we have less insect problems in these rooms, with the added benefit of the rooms being heated and cooled. The rooms have reliefs in them. As long as its not a Boiler Room, which would be illegal, I don't see what the problem would be.
    I only have to make it work till I retire, two more months
  15. #11
    Mar 2018
    The only equipment in the room is the cooling equipment
  16. #12
    Mar 2015
    Hamersville, Ohio
    Interesting.
    But I can see where concerns for Fire Spread,Chemical contamination,& more do arise.
    And that is why, "Return Air" from a Mechanical, Utility, &/or, Bathrooms,as well as Kitchens is prohibited.
  17. #13
    There are duct Smoke detectors on both the return and supplies, there are Smoke dampers on the units. Smoke Detectors in the Mechanical Rooms. We are limited to what we can use for cleaning in the Mechanical Rooms, also when we do cleaning with chemicals, Emails are sent out to the building occupants, along with notices posted in the building. Often cleaning is done after hours or on the weekends. BTW this is not a Plenum Mechanical Room, just Relief air from the building. BTW we do have one old Mechanical Room that is the return, but the relief isn't in that room. Outside fresh air is ducted to that unit.
  18. Likes DavidDeBord liked this post
Tags for this Thread
