Results 1 to 6 of 6
    Mar 2018
    is a CONDENSER the only difference between 2.5 ton and 3 ton unit?
    I posted a few months ago that the contractor that put in our new HVAC put in a 3 ton unit instead of the 2.5 ton that should have been installed. He has assured me that when we are ready, he will switch out the 3 ton and replace it with the 2.5 ton. The time has now come to do it and I noticed on the paperwork he emailed me that it shows that they will only be replacing the CONDENSER only. Does this make sense to you guys that understand HVAC? I just want to make sure that they are not just rigging it so they don't have to replace the whole unit. Is there any advantage to starting from scratch and replacing the whole 3 ton unit with a 2.5 ton instead of just replacing the CONDENSER?
    I appreciate any advice you can give me!
    SW FL
    Quote Originally Posted by jaxon78727 View Post
    There are only 3 major components:
    1. Air Handling Unit - A.H.U. ( a.k.a. blower; INside)
    2. Condensing Unit ( a.k.a. Condenser = compressor with coils ) ( Outside )
    3. Thermostat
    Nearly all A.H.U.s are multi -speed set-up with various dip switch combinations
    .:. You only need the Condenser replaced
    _ _ IF the ACCA Manual J calculation that is independently reviewer
    _ _ indicates a 2.5 Ton ( ACCA Manual S calc ) system is the appropriate selection.
    http://www.contractingbusiness.com/a...-acca-manual-s
    Designer Dan
    Very common to have a larger rated air handler on a smaller condenser.
    Model # of the indoor air handler or coil?
    Jun 2014
    Dover, DE
    Ask for the AHRI match number
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
  6. Likes ziggyhere liked this post
  7. #6
    Mar 2010
    Woodbridge, VA
    Quote Originally Posted by rider77 View Post
    And make sure it's set up for the correct blower speed
