Results 1 to 4 of 4
Thread: Ptac mold smell
    Sep 2010
    miami,fl.
    Ptac mold smell
    So I have a customer that has about 40 ptac wall ac units. This one particular seems to hold a mold/mildewy scent. The maintenance guy said they clean it every month to try to keep the smell down. I do not know if they are cleaning with chemical like coil cleaner. So I am on here to ask if you all know of a good product to spray on the unit to keep the mold down and also the scent. I believe it’s building up on the blower wheel like a minisplit.
    Dec 2016
    I've had good luck with PTAC UV germicidal lights as well as Ionizers, Nu-Calgone and RFG both make products that would probably work.
    http://www.nucalgon.com/products/iaq/iWave-F
    http://www.nucalgon.com/products/iaq...m-air-purifier
    https://www.rgf.com/products/air/ptac-air-purifier/
    New Mexico
    It might be that the condensate isn't draining well. Mold smell can be a symptom of a bigger problem.
    You could check for any standing water inside or a mouse.
    I should have played the g'tar on the MTV. MK
    You can be anything you want......As long as you don't suck at it.
    SMW Lu49
    Athens, Ohio
    Quote Originally Posted by hvacker View Post
    This includes checking the slope of the unit and the "outdoor" half of the unit. I've seen them become loaded with sludge which prevents the indoor portion from draining.
    AOP Rules: Rules For Equipment Owners.
    Free online load calculator: http://www.loadcalc.net/
    There = not here. Their = possessive pronoun. They're = they are
    It's = contraction of it is. Its = the possessive form of it
    Too = also. To = expressing motion. Two = 2
    Then = after that, next. Than = indicates a comparison.
    Questions should end with a question mark "?" Statements end with a period "."
