Results 1 to 9 of 9
    Mar 2011
    Midwest
    RECLAIMING R-11 CENTRAVAC
    I have personally done about a 1/2 dozen 19 XR tear downs and a couple of Tranes CHVE with R-123 in them . Starting a 1983 Trane CHVE045 with R-11 this week . What's a good vacuum to verified I got the Gold out of it .
    Reusing the Refrigerant all said and done .
    Never mind found it and with a few derogatory comments on the post by the usually suspect . Happy Monday
    Kentucky
    first one i did only took it yo -14" wc but back together woo and be-hold was 300 pound short customer and boss was pissed, that was the 70's now we know to go at least -24"wc or vacuum! retired now don't give a rat's ass!
  3. Likes Nuclrchiller liked this post
  4. #3
    Mar 2011
    Midwest
    thanks Mathias ,
    Enjoy the well deserve Retirement . Hope all body parts are working well from this trade . Alexa told me today I had 1947 days left ,but who is counting . Cheers
  5. #4
    May 2012
    California
    Epa 25 mm hg
    Sent from my SM-G930V using Tapatalk
  6. #5
    up in the hizzy
    Quote Originally Posted by JEF1980 View Post
    Epa 25 mm hg
    Correct 25mmhg or 28.9", I use a vacuum gauge and recover down to 25000 microns if the machine has no leaks.
    There is not better place for the working men than the union! 100% UA the only HVAC union!
  7. #6
    Mar 2011
    Midwest
    Proud 597UA Chicago myself . 28.9 . 25,000 it will be . Thanks Brother
  8. #7
    Houston TX
    I like to run chiller water through the recovery system, gives a vapor pull down. I like to go over EPA guidelines to 29" hg. No micron is necessary at this point. I have several school district maint. techs, who think 20" hg is max. Needless to say I spend my first day completing their recovery and of course there is always air in the system. I have a old Trane oil pressure regulator set at 6# to allow non-condonsables to escape again using chilled water as the condensing medium.
    Once in a while everything falls into place and I am able to move forward, most of the time it just falls all over the place and I can't go anywhere-GEO
  9. Likes CHILLERSVCMAN, Nuclrchiller liked this post
  10. #8
    If I suspect air may play a role, I will setup our portable purge to remove air from the tank.
    Technically speaking, they are all heat pumps.
  11. Likes CHILLERSVCMAN, Nuclrchiller liked this post
  12. #9
    Houston TX
    Jayguy - I agree that a purge would work great, however I have used chilled water to condense the vapor and it gelps seperating it out. I hear my relief valve belch several times. After warming up to room temp I am very close in pressure temp. If I had the option of a portable purge unit I would use it instead, but it is what it is. -GEO
  13. Likes jayguy, Nuclrchiller liked this post
