Page 7 of 7 FirstFirst 1234567
Results 79 to 86 of 86
  1. #79
    Mar 2018
    Maryland
    I installed a desert-Aire last year. That stuff is serious. I was amazed when the startup guy came out and ran through it with me. Mad respect for those guys✊
  2. #80
    Apr 2005
    Australia : Queensland
    These units are Fantastic.
    http://www.airchange.com.au
    The primary function of the design engineer is to make things difficult for the fabricator and impossible for the serviceman.
  3. #81
    Apr 2003
    Maple Grove, MN
    Here's a dumb question. Can the condensate from a humidifier or Pool Pak or Dectron or whatever be piped back into the pool?
    If at First You Don't Succeed, Skydiving Is Not for You.
  4. #82
    Jun 2014
    Dover, DE
    Quote Originally Posted by ammoniadog View Post
    No, messes with the pool chemistry
    I havent failed. Ive just found 10,000 ways that wont work. - Thomas Edison
    Its not whether you get knocked down, its whether you get up. - Vince Lombardi
    "In this house we obey the laws of thermodynamics" - Homer Simpson
  5. #83
    Apr 2005
    Not here. Needs to be Plumbed to Storm-Water or Waste.
  6. #84
    Mar 2015
    Medford, N.Y.
    I thought that piping the condensate back to the pool was a "part of the package". You can do it as an economy thing or not.
  7. #85
    Quote Originally Posted by TechmanTerry View Post
    Never seen it done. Always ran to a drain on everyone I've seen and worked on.
  8. #86
    Mar 2018
    Montreal, Canada
    +1 on dry-o-tron or desert aire etc.
    That application calls for a purpose-built dehumidifier. You'll have an outdoor commercial split style condenser for cooling in summer and it will heat your pool water at the same time. It's a vicious cycle type of system. I don't see how mini splits would ever fit the bill.
    They require backup heat downstream of the unit supply plenum and boilers for heating the pool water as well.
    Post edited for mistake and addition.
