Results 1 to 11 of 11
    Mar 2018
    Airtemp/Chrysler Old unit
    Hello all,
    Has anyone heard of a Airtemp or Chrysler 3105-02R air conditioner? Very old unit I am looking to replace, but I cannot find anything for the life of me.
    Please let me know
    I am at a loss
    -Chris
    Jan 2014
    New England
    Any numbers from the metering device to get a general tonnage, the ones we worked on where R12 refrigerant.
    http://www.localinspectioncompany.co...les/acdata.pdf
    3105 according to the above site says it's a 4 ton??
  3. Likes HVAC_Marc liked this post
  4. #3
    Mar 2018
    Got the nameplate data now but can't post because I am new
    R-22 Refrigerant
    8.4 lbs
    480 psi high side
    150 low side
  5. #4
    Apr 2003
    Maple Grove, MN
    I think Fiat deals with those now, try giving them a call.
    I'm just being a smart ass. I've seen a few of those around, but I don't think any of them were operational by the time I saw them. Neat old pieces of history though.
    If at First You Don't Succeed, Skydiving Is Not for You.
  6. #5
    New Mexico
    Calculate the load. Old equipment was often way off.
    I should have played the g'tar on the MTV. MK
    You can be anything you want......As long as you don't suck at it.
    USAF 98 Bomb Wing 1960-66 SMW Lu49
  7. #6
    The Airtemp name is being used by distributor R. E. Michel. No relation to the oldies. They just bought the use of the name from someone.
  8. #7
    Oct 2015
    Illinois
    If it is a chrysler that is an old unit. I ran into them in my early years and they were old then and that was late 80s ish.
    If that is the case do the load calc. House has probably had insulation added since then and probably newer windows. Be sure to check the walls and if they have been insulated.
    There is only one truly right way to do something, but there are thousands of wrong ways to varying degrees to do it.
    So the question is: If you don't do it right, then how wrong is it going to be???
  9. #8
    Austin, TX
    I just finished replacing two Chrysler Airtemp split units, both were 1970 units. There are small foil data plates on the evap coil that should give you toneage if they have not fallen off.
  10. #9
    I worked those in the late sixties to late seventies. If I remember correctly they had nice colors. Like orange and blue cabinets.
  11. #10
    Apr 2004
    Waterloo N.Y.
    They always had transmissions or rear axles replaced!
    There's TREACHERY AFOOT!!!
  12. #11
    At least they didn't sound like a haunted house when driving them around.
    PHM
    Quote Originally Posted by mcr View Post
    PHM
