Results 14 to 26 of 27
Thread: Ouch!
    Near New orleans
    Man dude that sucks. never thought gloves would do that. just one more reason not to wear them. i had the opposite to me had the torches going and basically melted them to my hand. Let use know the brand or style of gloves.
    Sep 2006
    The depths of hell in PHX AZ
    I did that back in school MANY years ago. Switching out the old recovery jugs on the monster carts they had back then. Jug wasnt off. I turned it off with liquid spraying. Used one hand till it jurt bad then switch to the other.
    I felt your pain. It sucks
    But I learned early on not to EVER care again if it blows.
    I will believe that the government is broke when the welfare checks start bouncing!!
    Altmar, New York, United States
    i had somthing like that happen also, but it was a mapp gas bottle. i just installed a water heater and was taking my torch apart. when i took the head off the valve in the bottle stayed wide open. in a moment of panic i put it aginst my leg so i wasn't dumping gas into the mechanical room. by the time i got outside it had burned a hole in my pants and left a huge nasty blister that i had to go to the emergency room to be treated. now i have a battle wound the size of a coffee cup. if i was smart i would have just put the torch head back on. hind sight is 20/20.
    Apr 2006
    South West Ohio
    I have been burnt, But not that bad. Your first reaction is to grab that cap and try to get it on. It only takes one time getting burnt and you will let it fly.
    Sorry to hear about your hand. I Know the 1st instinct is to jump in and stop it but let it go.
    I use Core Pulling tools and Good Leather gloves
    Jun 2007
    Darby, PA
    I now have a core removal tool and a good, thick pair of leather gloves---just in case.
    Psalm 51:10, 12
    Aug 2008
    at least u can still give someone the bird important fingers are still there
    Nov 2003
    Montreal, Qc.
    ...I use Core Pulling tools and Good Leather gloves
    Exactly.
    I have one customer that still has one of my core pulling tools attached to his unit.
    I replaced a seal and a schrader in a king valve for a liquid line only to find out that the schrader leaks after charging the whole system.
    I tried for 20 minutes to get the schrader to pop back out so that I could replace it but it was being stubborn.
    I left the core tool in place and will retrieve it in the spring when I go back.
    Oct 2009
    St Pete, FL
    We got to see the core removal tool in class yesterday and play around with it. For less than 50 bucks apiece, I think I'll have several when I'm out in the field someday.
    Thanks for the pics of the hand. We can all learn from your pain...
    Sorry you had to get hurt, and hope ya heal up soon.
    Keith
    Nov 2007
    Sherman, TX
    Been there, done that. Always seems to be in a supermarket on a rack system.
    It's gonna hurt like hell in a few days. Be VERY careful when it breaks, not to let it get infected.
    And, no.......hiner milk won't make it feel better.....
    Technical incompetence is NOT a sales tool....
    Jan 2005
    North Ala
    well i done it with 134a....and i can say its even worse...froze a welding glove to my hand tring not to lose 100lb of 134a... let her blow baby let her blow... you need to get you some Silvadene Cream.... get a big bowl of that crap...if you ever burn your self put it on heavy... believe it or not it can help prevent a injury that bad...i also stuck a 1 3/8 line to my arm one year from a rev valve,,,was torching tring to do a 2 man job myself and see stuck to my arm,,,had to pry it off... anyways get some of that cream...it has saved my idiot butt many times over the years...
    CRab
    Float'N Vally, MS
    Not good....
    Heard stories of tech's loosing fingers from freon burns!
    Hope you heal fast!
    Life is too short, Behappy!
    TFMM
    Jan 2005
    North Ala
    o....and one more thing...if you get a burn wrap it in a clean shirt or something...an try and warm your hand right when it happens...DO NOT run water over it yet...seen a guy do that once and it cooled too quick, skin just rolled off like dirt..
    hope this helps
    Crab
