Results 1 to 13 of 19
Thread: Why?!?
    Austin, TX
    Why?!?
    Why? What...I mean....I.....WHY!
    If you're too "open" minded, your brains will fall out.
    Artificial intelligence is no match for natural stupidity.
    where it's nice and warm
    The thermostat wire is too small or the run is too long.
    That is not "wall of shame" material.
  3. Likes buford liked this post
  4. #3
    Austin, TX
    To small or too long for y1 but it's okay to wire y2 to y1 and the relay for y1?
  5. #4
    Aug 2009
    Beatrice, NE
    I was thinking isolation relay but what is the reason for the blue wire as it will not be isolated at that point.
  6. #5
    Austin, TX
    Quote Originally Posted by BNME8EZ View Post
    That was my first thought as well.
  7. #6
    Jan 2003
    Kansas City
    It makes a double click......click on......click offf......The Clicker..
    Sent from my SM-G900V using Tapatalk
  8. #7
    Dec 2012
    columbus, OH
    Quote Originally Posted by james mo View Post
    Lol
    Sent from my SM-S320VL using Tapatalk
  9. #8
    Aug 2013
    N/A
    Why is Y2(BL) going to Y1?
    I get the relay, but, Y2 on Y1, when it's a 2 stage unit....is confusing me?
    Even if they're twinned on the back of the TB, there'd be no need for blue?
    Actually, the relay doesn't make any sense either: If the signal coming back from the tstat is strong enough to energize the relay coil, then it would be strong enough to then activate the CC1 coil?
    UNLESS, there is an economizer?
  10. #9
    Jan 2003
    Kansas City
    Reset breaker...$89.95
    Replace 1st stage sequence control relay module... $369.95
  11. #10
    Apr 2010
    Tecumseh Valley
    It probably was, until someone decided to jump the stages together, without thinking about what they were seeing. Is this a national account, by any chance?
  12. #11
    in a house, Appomattox, Va.
    they have a nest downstairs
    Col 3:23
  13. Likes beshvac, mark beiser, HVAC_Marc liked this post
  14. #12
    Dec 2012
    columbus, OH
    Depending on the setup it could be usefull
  15. #13
    Nov 2011
    East Side
    It could only be useful if you have 2 separate 24v power sources connected together. All you have to do if it's blowing fuses is swap common and hot at one transformer. Someone didn't know how to fix the real problem, but this "worked".....
