+ Reply to Thread
Results 1 to 18 of 18
Thread: non-brass flare nut??
    Oct 2002
    Plano, TX
    PRZ inspector doesn't want copper or brass connection to coffee brewer.
    How do I make the connection to the 1/4"male flare on the equipment?
    Please, specific details. It won't help to know to use SS nut, unless you can tell me where to find this?
    Nov 2016
    Would your inspector accept a plastic John Guest fitting?
    Sent from my XT1585 using Tapatalk
    May 2014
    Bay Area California
    Why?
    The flare nut never touches the product.
    Jan 2015
    Bellevue, Washington, United States
    That makes no sense. What if you used a braided stainless hose with flares
    Oct 2002
    Plano, TX
    Cannot find info on that.
    Quote Originally Posted by howerpeter View Post
    Oct 2002
    Plano, TX
    Good idea. How to connct to plastic 1/4" without using brass or copper?
    Quote Originally Posted by James Colver View Post
    Nov 2016
    Quote Originally Posted by timjimbob View Post
    1/4 PEX?
    Dec 2012
    Illinois
    Bev Flex
    I'll take a picture in a bit.
    Jul 2001
    Asheville,NC
    I did a little searching as to why...
    This is from the North Carolina Food Code Manual (2009)-
    "4-101.14 Copper, Use Limitation.
    (A) Except as specified in ¶ (B) of this section, copper and
    copper alloys such as brass may not be used in contact with a
    FOOD that has a pH below 6 such as vinegar, fruit JUICE, or wine
    or for a fitting or tubing installed between a backflow prevention
    device and a carbonator. P
    (B) Copper and copper alloys may be used in contact with beer
    brewing ingredients that have a pH below 6 in the
    prefermentation and fermentation steps of a beer brewing
    operation such as a brewpub or microbrewery."
    Coffee is mildly acidic, around 4.5 PH.
    Oct 2002
    Plano, TX
    I realize I have used John Guest fittings for years, yet there still is no option I have found to connect a non copper/brass female flare to a male flare on the dispenser. This inspector better have a solution-I think he is overly stuck on being unrealistic.
    Nov 2016
    What about one of these to a stub connector to your 1/4 line?
    Oct 2002
    Plano, TX
    Well there you go! I missed that.
    Nov 2016
    If you can't tell that is right from the Walmart app, or Grainger if you need an odd size
  14. #14
    Jan 2010
    Sea to Sky
    Sure but is this the water inlet line? Last I checked only water went in there and coffee came out the business end into the pot.
    Quote Originally Posted by drewwells View Post
    Sent from my SM-N910W8 using Tapatalk
  15. #15
    Oct 2002
    Plano, TX
    Actually, this is only a hot water dispenser. water is 7ish around here, both in and out.
  16. #16
    May 2014
    Bay Area California
    I'm still trying to figure out how the water touches the flare nut.
  17. #17
    Nov 2016
    I have a question is this a newer inspector? I have had a newer health inspector try to tell me a walk-in freezer was out of temp when it was in defrost. Is he just digging¿
  18. #18
    Oct 2002
    Plano, TX
    Inspectors sometimes use a "weighted" thermometer that averages the temp over a period of time, thus taking into account times when door is open or defrosting.
+ Reply to Thread
Quick Reply Quick Reply
Register Now
Log-in
  • You may post new threads
  • You may post replies
